1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules)
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Mar 2004 14:30:19 -0500
Andrew Johnson wrote:
> Kate Feng wrote:
> > Measured 60x bus bandwidth (MPC7450 + GT64260) :
> >     Pipelining  disabled : 177 MBytes/sec
> >     Pipelining  enabled :  589 MBytes/sec
> > Thus, theoretically, one should be able to disable  the
> > address pipelining  of the mvme5500 (MPC7455 + GT64260).
> There's no way of getting 589MB/s through a regular VMEbus.
Perhaps I forgot to mention that the paper was based on work done
on  an  evaluation board without  the VME bus.   However, I did not
say one can get that 589 MB/s through a regular VME bus.
It is just a reference number to describe the possibility of
disabling the  address pipelining on the mvme5500.
> Address pipelining on the VMEbus (which was causing the problems with the
> VME-MXI-1 modules) is not related to address pipelining by the CPU on its
> local bus, which is presumably what the Motorola paper is quoting.
I did not say it was quoted by Motorola.  I said it was brought up by
someone in the tech-talk discussion.   Now I looked  back  at the archiver.
Oh, it was quoted by  someone  from APS  submitted to tech-talk
on  Fri, 14 Nov 2003 10:52:45 -060.
> The
> VMEbus cycle timings are completely controlled by the Tundra Universe-2
> chip on Motorola PowerPC boards, and VMEbus address pipelining cannot be
> disabled.
This is yet to be verified.   However, in the previous tech-talk   it was
quoted :
>  The APS has a rather large number of these modules. The flaw in the
VME-MXI-1
> has not caused problems because the modules have been used only
> with MVME167 CPU modules which do not perform address pipelining. We now
> want to upgrade some of these MVME167 IOCs to more modern CPU
> modules, but we've run into a problem. CPU modules with a UNIVERSE-II VME
interface
> chip (all Motorola 2100, 5100 and 5500 series) do perform
> address pipelining which results in erratic data transfer from VME-MXI-1
modules.
> My guess is that it is likely that any modern CPU is going to cause the
same problem.
Now you are telling me a different story.
Kate
mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Prev: modtcp channel status Eric Williams
Next: RE: EPICS on MVME2100 series? Sibley III, Coles
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Next: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
