Kate Feng wrote: > > Please do not forget the system controller is in between the CPU and the > VME slave. You have either your nomenclature or your understanding of the architecture confused. The Universe-2 is between the CPU and the VME slave, but as I explained it can completely decouple the cycles on the two busses in some cases, and in others (such as VMEbus IACK cycles) there is no equivalent PCIbus cycle going on at all. > How can the CPU see the DTACK asserted by the slave if the system > controller is holding it up until the right time ? The CPU doesn't see DTACK, the Universe-2 chip does, and it doesn't go through the system controller (go back and read my last message again, where I say CPU I really mean the PowerPC processor chip via its PCI host bridge). In the case of a Read cycle the Universe-2 will read the data off the VMEbus and pass it back to the CPU and finish the pending PCIbus read cycle. However for a posted write cycle there is no reason to delay the CPU until the write completes, as it may be able to execute tens or even hundreds of instructions between performing the PCIbus write cycle and the VMEbus cycle completing. The Universe-2 chip is not a simple VME signal interface like I suspect the Motorola VMEchip device was; there really is a lot going on under the hood, and it only couples the two busses together (i.e. delays its response on one while it's waiting for a related response on the other) if they really need to be coupled. That generally only occurs when the CPU does a read from a VMEbus address, or another VMEbus master does a read of memory on this card. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
