Mark,
Wind River gave me the code shown below. I load this before IocInit and have
played with buffer size adjustments. For example:
ld < /ata0/ethShow.o
changeIfSendQMax("elt0",2000)
When I have network problems, I do the following:
ifQValuesShow("elt0")
and I always see
elt0 drops = <some number> queue length = 2000 max_len = 2000
Before things get into this state, ifQValuesShow("elt0") always gives
elt0 drops = 0 queue length = 0 max_len = 2000
At this point, network communications have ceased and I must reboot. I don't
know what causes this and I started down the path of upgrading to tornado
2.2.1. EPICS, however, does not build.
I only see this on one IOC that sustains a high level of network traffic (CA,
Allen/Bradley ethernet PLC, MOXA ethernet-to-serial devices).
The buffer size adjustment makes the problem less frequent, but it has not
gone away.
Wind river hinted that their ethernet driver might have a problem. This
inspired the attempt to upgrade to 2.2.1.
I'm running version 3.13.6.
John Sinclair, ORNL
* THIS CODE IS NOT SUPPORTED CODE. IT IS PROVIDED ON AN AS-IS BASIS.
#include "vxWorks.h"
#include "ifLib.h"
#include "etherLib.h"
#include "stdio.h"
#include "net/if.h"
#include "net/unixLib.h"
#include "netBufLib.h"
#include "end.h"
#include "muxLib.h"
#include "netShow.h"
#include "stdio.h"
IMPORT struct ifqueue ipintrq;
IMPORT struct ifqueue arpintrq;
IMPORT void netPoolShow (NET_POOL_ID pNetPool);
* changeProtocolInputQMax - Change IP and ARP input queue maximum length
* Default configuration sets these values to 50 packets
* each.
void changeProtocolInputQMax
int ipQNewSize, /* Default is 50 */
int arpQNewSize /* Default is 50 */
int s;
printf("IP input maximum queue length = %d\n", ipintrq.ifq_maxlen);
printf("Arp input maximum queue length = %d\n", arpintrq.ifq_maxlen);
s = splnet();
arpintrq.ifq_maxlen = arpQNewSize;
ipintrq.ifq_maxlen = ipQNewSize;
splx(s);
printf("New IP input maximum queue length = %d\n", ipintrq.ifq_maxlen);
printf("New Arp input maximum queue length = %d\n", arpintrq.ifq_maxlen);
return;
void protocolQValuesShow (void)
printf("IP receive queue max size = %d\n", ipintrq.ifq_maxlen);
printf("IP receive queue drops = %d\n\n", ipintrq.ifq_drops);
printf("ARP receive queue max size = %d\n", arpintrq.ifq_maxlen);
printf("ARP receive queue drops = %d\n", arpintrq.ifq_drops);
return;
* ifQValuesShow - Show number of times packets were dropped because interface
* send was full.
* name
* Expects the interface name plus the unit number: dc0, fei0
void ifQValuesShow
char *name
struct ifnet *ifp;
ifp = ifunit(name);
if (ifp == NULL)
printf("Could not find %s interface\n", name);
return;
printf("%s drops = %d queue length = %d max_len = %d \n", name,
ifp->if_snd.ifq_drops,
ifp->if_snd.ifq_len, ifp->if_snd.ifq_maxlen);
return;
* changeIfSendQMax - Change interface send queue length.
* name expects the interface name plus the unit number: dc0, fei0
* len: New length. Default configuration sets this value to 50.
void changeIfSendQMax
char *name,
int len
struct ifnet *ifp;
int s;
ifp = ifunit(name);
if (ifp == NULL)
return;
printf("%s previous queue length was %d\n", name, ifp->if_snd.ifq_maxlen);
s = splnet();
ifp->if_snd.ifq_maxlen = len;
splx(s);
printf("Queue length set at: %d\n", ifp->if_snd.ifq_maxlen);
return;
* endMibShow - Show the contents of the MIB2 table for end drivers.
* Output errors can be errors while transmitting or dropped packets due to
* driver's out of buffers error condition. Input errors can be packets
* received
* with errors or packets dropped due to driver's out of buffers error
* condition.
* See endPoolShow below.
void endMibShow
char * devName,
int unit
END_OBJ * pEnd;
if ((pEnd = endFindByName (devName, unit)) == NULL)
printf ("Could not find device %s\n", devName);
return;
printf("Mib table statistics for %s%d:\n", devName, unit);
printf("Output errors = %lu ", pEnd->mib2Tbl.ifOutErrors);
printf("Output Packets = %lu\n", pEnd->mib2Tbl.ifOutUcastPkts);
printf("Input errors = %lu\n", pEnd->mib2Tbl.ifInErrors);
printf("Unknown protocols = %lu\n", pEnd->mib2Tbl.ifInUnknownProtos);
return;
* endPoolShow - Show the status of the private memory pool for end drivers.
* The total number of clusters is usually equal to the sum of the number of
* transmit,
* receive and loan buffer descriptors that a driver is initialized with.
* See the External Interface section for the driver's library description in
* the
* vxWorks Reference manual (i.e dec21x40End), the driver's header file, and
* conf igNet.h
* for the default values.
* If the number of free buffers is 0, the device will be unable to either
* transmit
* (Mib 2 output errors will increase) or receive packets (The Mib table input
* errors
* statistics will increase).
* Why would the free pool drop to 0? Most common reason is task not reading a
* socket.
* Drivers lend buffers to the stack which are not freed until the socket is
* read
void endPoolShow
char * devName, /* The inteface name: "dc", "ln" ...*/
int unit /* the unit number: usually 0 */
END_OBJ * pEnd;
if ((pEnd = endFindByName (devName, unit)) != NULL)
netPoolShow (pEnd->pNetPool);
else
return;
* changeMtu - Change default interface MTU.
void changeMtu
char *ifName,
int newSize
struct ifnet *ifp;
int s;
ifp = ifunit(ifName);
if (ifp == NULL)
printf("Could not find %s interface\n", ifName);
return;
printf("Previous MTU for %s was %ld\n", ifName, ifp->if_mtu);
s = splnet();
ifp->if_mtu = newSize;
splx(s);
printf("MTU is now set at: %ld\n", ifp->if_mtu);
return;
void changeSendQueueLength
char *name,
int len
struct ifnet *ifp;
int s;
ifp = ifunit(name);
if (ifp == NULL)
return;
s = splnet();
splx(s);
return;
On Wednesday 24 March 2004 05:30 pm, Mark Rivers wrote:
> Andrew,
> > I'm not quite sure what causes ENOBUFS errors when
> > sending CA beacons; I have seen similar errors on IOCs here that have
> > never run out of DataPool or SysPool buffers, and I don't yet
> > know what they're complaining about (any ideas Jeff?). They do appear
> > to be benign though, if my memory is correct - the loss of a beacon
> can cause some
> > unnecessary CA searches to occur, but nothing should break.
> Things are not benign for us, though the CA error messages may just be
> symptomatic of deeper problems. We have lost NFS and CA connectivity,
> and we have to reboot. It runs for a while, and then it happens again.
> I suspect there is a machine on the network there that is infected with
> some virus, and periodically blasting each machine on the network.
> Disconnecting the beamline switch from the network has fixed the
> problem, but of course that means I can't diagnose it from here at
> Argonne.
> Mark
John Sinclair
- RE: Buffer problems Mark Rivers
RE: Buffer problems Jeff Hill
<2004>
2025
2026
Re: Buffer problems Tim Mooney
<2004>
2025
2026
