1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tornado 2.2.1
To: Dirk Zimoch <[email protected]>
Cc: tech talk <[email protected]>
Date: Thu, 25 Mar 2004 18:02:58 +0000 (GMT)
Hi Dick, Ron,
I got round this by adding __STRICT_ANSI__ within
vxWorks.h like this:
(This is line number 199)
#if defined( __STRICT_ANSI__ )
 * In case TOOL_FAMILY isn't defined, we shal assume gnu for
 * backward compatibility.  All this is so we can include
 * the toolMacros.h file from the h/tool/$(TOOL_FAMILY) directory
 * path.  This is needed because for host tool building we can't
 * always specify additional include paths for compiler tool
 * builds.
#ifndef TOOL_FAMILY
#   define TOOL_FAMILY gnu
#endif
/* All this to generate a string we can #include */
#define TOOL_HDR_STRINGIFY(x)  #x
#define TOOL_HDR(tc, file) TOOL_HDR_STRINGIFY(tool/tc/file)
#define TOOL_HEADER(file) TOOL_HDR(TOOL_FAMILY,file)
/* Now include the correct header file */
#include TOOL_HEADER(toolMacros.h)
#endif  /* __STRICT_ANSI__ */
Cheers,
Andy
On Thu, 25 Mar 2004, Dirk Zimoch wrote:
> Ronald L. Sluiter wrote:
> > I am beginning to wonder if there is any combination of compiler
> > switches that will allow one to build R3.13.9 using Tornado 2.2.1
> Yes. Tornado2.2 vxWorks.h is not compatible with the -traditional flag.
> > I don't understand it, but here is what is happening to drvBitBus.c.
> > The following is a segment from vxWorks.h;
> > The above "#include TOOL_HEADER(toolMacros.h)" is processed into
> > the following in drvBitBus.c;
> >    #tool/gnu/toolMacros.h
> > It is like the "include" part of "#include" got lost.  This yields the
> > error message;
> > ..../wind68K2.2/target/h/vxWorks.h:218: `#include' expects "FILENAME" or
> > <FILENAME>
> > Ron
> I think, with the -traditional flag, the preprocessor does not know the
> '#x' stringify feature. Thus, the line expands to:
> #include #GNU/tc/toolMacros.h
> Now, the preprocessor gets lost.
> I've removed the -traditional flag everywhere and found, that the
> problems with src/drv/old are (mainly?) because of sloppy/lazy/buggy
> programming:
> There are just not enough arguments provided to logMsg() and
> taskSpawn(). Solution: fill with 0's.
> I've not tried it because the bug occurs quite often in several files,
> but it should help.
> Dirk
> Dr. Dirk Zimoch
> Swiss Light Source
> Paul Scherrer Institut
> Computing and Controls
> phone +41 56 310 5182
> fax   +41 56 310 4413
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Re: Tornado 2.2.1 Dirk Zimoch
Prev: Re: Tornado 2.2.1 Dirk Zimoch
Next: some of my scan tasks are not being processed because of long delays. Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Collab. Meeting - Alb-Santa Fe Shuttles Bob Dalesio
