1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ezcaIDL ELF class error
To: "Paul Sichta" <[email protected]>, <[email protected]>
Date: Tue, 30 Mar 2004 10:29:29 -0600
Paul,
> IDL> sts=caversion()
> % CALL_EXTERNAL: Error loading sharable executable.
>                  Symbol: EzcaVersion, File = libezcaIDL.so
>                  ld.so.1:
> /usr/local/rsi/idl_5.5/bin/bin.solaris2.sparc64/idl
>                  : fatal:
> /epbld/extensions/lib/solaris/libezcaIDL.so: wrong
>                  ELF class: ELFCLASS32
> % Execution halted at: CALL_EZCA          79
>   /epbld/extensions/bin/solaris/ezcaIDL.pro
> %                      CAVERSION        1480
> %                      $MAIN$
ezcaIDL is built for 32 bits.  You are running the 64-bit version of
IDL, so it won't work.  If you run the 32-bit version of IDL, which is
included on Solaris, then it should work.
Prev: ezcaIDL ELF class error Paul Sichta
Next: Re: ezcaIDL ELF class error Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ezcaIDL ELF class error Steven Hartman
Next: Re: ezcaIDL ELF class error Ben-chin K. Cha
