>I am having a problem using ezcaIDL with idl 5.5, things
>work fine on the same computer using idl 5.3. The error is
>shown below. The OS is Solaris 5.8 (on sparc).
Currently ezcaIDL is built as 32 bit sharable library.
Starting from IDL 5.5 for solaris it assumed that 64 bit code is used.
But it provides an option '-32' on the command line, it allows the user
to run IDL with 32 bit sharable library.
In order to access the ezcaIDL CA command, you have to start the IDL
with '-32' option:
idl -32
>Also, is anyone using ezcaIDL with idl 6.0, on Solaris or
>Linux?
At APS we are running both IDL 6.0 and IDL 5.5 on Solaris.
Ben-chin
RE: CA client: Where should ca_current_context() be used? Jeff Hill
Re: Query on more EDM widgets steiner
<2004>
2025
2026
RE: ezcaIDL ELF class error Mark Rivers
CA client: Where should ca_current_context() be used? Liyu, Andrei
<2004>
2025
2026
