idle (nothing had been written to the log files for at least 5 hours). The three log files show that the three IOCs (LGA, PIE, and FAT) experience the same error: LGA: 2004-04-05,16:07:12: 0x760408 (tNetTask): ei driver: command field frozen PIE: 2004-04-05,16:07:12: 0x760408 (tNetTask): ei driver: command field frozen FAT: 2004-04-05,16:07:28: 0xf60408 (tNetTask): ei driver: command field frozen Each of the log files shows that the ENOBUFS and save/restore errors occurred 1-3 minutes later and continued until each IOC was rebooted. Here are the errors that occurred: CAC: unexpected select fail: 851971=S_iosLib_INVALID_FILE_DESCRIPTOR 0x2174b4 (save_restore): save_file: Backup file (auto_sr/settings.savB) is bad. Writing a new one. 0x32d250 (CA_online): ../online_notify.c: CA beacon error was "S_errno_ENOBUFS" CAC: error = "S_errno_ENOBUFS" sending UDP msg to 164.54.216.255:5064 0x2174b4 (save_restore): save_file - unable to open file auto_sr/settings.savB 0x2174b4 (save_restore): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** 0x2174b4 (save_restore): save_restore:save_file: Can't write new backup file. I quit. 0x2174b4 (save_restore): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** sendto failed: S_errno_ENOBUFS CAC: error = "S_errno_ENOBUFS" sending UDP msg to 164.54.216.255:5064 sendto failed: S_errno_ENOBUFS We have seen the ENOBUFS errors occur in IOCs before without seeing the tNetTask error, however, in those cases only one IOC was affected. This is the first time we have seen both the tNetTask error and multiple IOCs have ENOBUFS problems simultaneously. Are these "command field frozen" errors occuring anywhere else? Kevin Peterson At 12:42 PM 3/29/2004 -0600, Mark Rivers wrote: Hi Ernest,
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
