The following is from an old copy of the "ei" driver, but it may still be relevant. As can be seen below, the "command field frozen" error message is from a software timeout that indicates the 82596 ethernet chip is unresponsive. /* ei82596End.c - END style Intel 82596 Ethernet network interface driver */ /* Copyright 1989-2000 Wind River Systems, Inc. */ #include "copyright_wrs.h" /* modification history -------------------- 02a,11jun00,ham removed reference to etherLib. 01z,27jan00,dat fixed use of NULL ... ... ... ... ... ... /******************************************************************************* * * ei82596Command - deliver a command to the 82596 via SCB * * This function causes the device to execute a command. It should be called * with interrupts from the device disabled. An error status is returned if * the command field does not return to zero, from a previous command, in a * reasonable amount of time. */ LOCAL STATUS ei82596Command(END_CTRL * pDrvCtrl, UINT16 cmd)
int loopy;
SCB *pScb;pScb = pDrvCtrl->pScb; for(loopy = 0x8000; loopy--;)
if(pScb->scbCommand == 0) /* wait for cmd zero */
break;
} if(loopy > 0)
pScb->scbCommand = cmd; /* fill in command */
sys596ChanAtn(pDrvCtrl->unit); /* channel attention */
return(OK);
else
logMsg("ei driver: command field frozen\n", 0, 0, 0, 0, 0, 0);
return(ERROR);
}Mark Rivers wrote: Kevin,
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
