Hi Marty,
This should work (given the database design caveats). In the general
case the answer is still "No".
Peregrine
Marty Kraimer wrote:
Peregrine M. McGehee wrote:
In which case a possible solution for a bidirectional record
(without custom record types but with custom device support) is:
record A : input record with custom dev sup, scan PASSIVE
record B : periodically scanned record, with FLNK to A
within A's read_xxx device support function:
if PUTF true then
grab VAL and write to hardware
else
read from hardware and write to VAL
This writes on demand from the CA client and reads periodically.
This should work but if anyone ever uses A in a different way, e.g. an
output link is directed to it then it will fail.
Marty
Peregrine M. McGehee Sloan Digital Sky Survey
LANL/LANSCE-8 and NMSU/Department of Astronomy
(505) 667-3273; MS H820, LANL, Los Alamos, NM 87545
- RE: Record processing knowledge of dbAccess context J. Frederick Bartlett
- Re: Record processing knowledge of dbAccess context Peregrine M. McGehee
- Re: Record processing knowledge of dbAccess context Marty Kraimer
<2004>
2025
2026
<2004>
2025
2026
