Many of the extension applications still require the Epics/Base 3.13
build rules. You can edit epics/base/configure/CONFIG_SITE and set the
values for COMPAT_TOOLS_313 and COMPAT_313 to YES and build base again.
You can also look at the SDDS, oagca, and SDDSepics makefiles in the
extensions tree. These makefiles work with both 3.13 and 3.14 build
rules. If the newer epics/extensions/configure directory exists it uses
the 3.14 build rules.
--Bob Soliday
David Decotigny wrote:
Sorry for the previous post again, I did not look at the right doc.
I post the way I made caex compile here, I hope it is the "right" way:
- cd anywhere
- "<EPICS_BASE>/bin/linux-x86/makeBasext.pl -b <EPICS_BASE>" to
generate a template
- untar caex in the src/ directory
- rename src/caex/Makefile.Host as Makefile, and customize the 2
includes (inspired from the simpleExt and exampleExt templates):
include $(TOP)/configure/CONFIG
include $(TOP)/configure/RULES
- update the DIRS variable in src/Makefile
Is it the general way to do the things correctly ?
BTW, http://ics-web1.sns.ornl.gov/edm/ seems to be down right now.
Sincerely,
- Extensions configuration/compilation David Decotigny
- Re: Extensions configuration/compilation David Decotigny
RE: Bidirectional device support Carl Lionberger
RE: Bidirectional device support Liyu, Andrei
<2004>
2025
2026
Re: Extensions configuration/compilation Janet Anderson
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
