1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Extensions configuration/compilation
To: David Decotigny <[email protected]>, [email protected]
Date: Tue, 13 Apr 2004 12:59:05 -0500
If an extension has a Makefile.Host and a Makefile that includes files
from $(TOP)/config it is a R3.13 type extension and you should use the
extensions/config tarfile files. Set EPICS_BASE in the RELEASE file
to your R3.14.5 base. R3.13 type extensions can be built with R3.14 base.
You can have both extensions/configure and extensions/config in the same
extensions top directory. The R3.13 type extensions will use the config
files and extensions that have been converted to R3.14 Makefiles will
use the configure directory files.
Janet
David Decotigny wrote:
Sorry for the previous post again, I did not look at the right doc.
I post the way I made caex compile here, I hope it is the "right" way:
- cd anywhere
- "<EPICS_BASE>/bin/linux-x86/makeBasext.pl -b <EPICS_BASE>" to generate a template
- untar caex in the src/ directory
- rename src/caex/Makefile.Host as Makefile, and customize the 2 includes (inspired from the simpleExt and exampleExt templates):
include $(TOP)/configure/CONFIG
include $(TOP)/configure/RULES
- update the DIRS variable in src/Makefile
Is it the general way to do the things correctly ?
BTW, http://ics-web1.sns.ornl.gov/edm/ seems to be down right now.
Sincerely,
Extensions configuration/compilation David Decotigny
Re: Extensions configuration/compilation David Decotigny
Prev: RE: Bidirectional device support Liyu, Andrei
Next: RE: Bidirectional device support Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Extensions configuration/compilation Robert Soliday
Next: MVME5110 Dirk Zimoch
