1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initialising an ao record from a constant DOL
To: "'Bob Dalesio'" <[email protected]>, [email protected]
Date: Fri, 23 Apr 2004 14:56:36 +0100
Even if a device did support this bumpless
changeover feature I would still have thought
that it should be overwritten by a constant DOL
just as it is if DOL is a link.
> -----Original Message-----
> From: Bob Dalesio [mailto:[email protected]]
> Sent: 23 April 2004 14:20
> To: Owens, PH (Peter); '[email protected]'; [email protected]
> Subject: Re: Initialising an ao record from a constant DOL
> As I recall, the analog output record does a read on
> initialization. This is required to support a bumpless
> reboot on hardware that was cleaver enough not to drive
> the value to 0 during a sysReset. As a result, the value
> field would be written over by whatever value is returned
> from the device support on initialization.
> It sounds like we need an option for not reading the value
> on reboot.
> Bob
> On Fri, 23 Apr 2004 14:37:23 +0100
>   "Owens, PH (Peter)" <[email protected]> wrote:
> >Yes, I tried that.
> >and also setting the VAL field.
> >I have also attempted to initialise the record from
> >the value read back from the device - but unfortunately
> >that
> >doesn't work either as the input is asynchronous.
> >Pete.
> >> Dear Pete;
> >> Have you try to use closed_loop mode with constant DOL
> >>such as the
> >> following.
> >> record(ao, "$(device):SETSIZE") {
> >>     field(DESC, "Pump Size")
> >>     field(DTYP, "ornlSerial")
> >>     field(OUT,  "@digitel mpc size p=1 u=$(port)
> >>m=$(unit)
> >> p1=$(pump)")
> >>     field(PINI, "YES")
> >>     field(DOL,  "100.0")
> >>     field(OMSL, "closed_loop")
> >>     field(EGU,  "l/s")
> >>     field(DRVL, "0.0")
> >>     field(DRVH, "1200.0")
> >>     field(LOPR, "0.0")
> >>     field(HOPR, "1200.0")
> >>     field(PREC, "0")
> >> Kukhee Kim
> >> Instrument & Control, KSTAR
> >> Korea Basic Science Institute
> >> 52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
> >> Korea
> >> Email: [email protected]
> >> Tel: +82 42 870 1616     Fax: +82 42 870 1609      Cell:
> >>+82
> >> 17 513 4849
> >> From: Owens, PH (Peter) [mailto:[email protected]]
> >> Sent: Saturday, April 17, 2004 12:11 AM
> >> To: [email protected]
> >> Subject: Initialising an ao record from a constant DOL
> >> I'm trying to initialise an analog output record
> >> by putting a constant in the DOL field (see below).
> >> But the VAL field gets set to zero rather than 100.
> >> The record does process and outputs this zero.
> >> I can work around this by Initialising from another
> >>record
> >> using clsed loop mode but it does seem to be a bit of a
> >>cludge
> >> (see commented out lines).
> >> What am I doing wrong?
> >>m=$(unit)
> >> p1=$(pump)")
> >>     field(PINI, "YES")
> >>     field(DOL,  "100.0")
> >> #    field(DOL,  "$(device):INITSIZE")
> >> #    field(OMSL, "closed_loop")
> >>     field(EGU,  "l/s")
> >>     field(DRVL, "0.0")
> >>     field(LOPR, "0.0")
> >>     field(PREC, "0")
> >> record(ai, "$(device):INITSIZE") {
> >>     field(VAL, "200.0")
> >> Pete
> >> phone:+44 (0)1925 603974
> >> fax:    +44 (0)1925 603124
> >> CLRC
> >> Daresbury Laboratory
> >> Keckwick Lane
> >> Warrington
> >> WA4 4AD
> >> UK
> Bob Dalesio
> [email protected]
> 410 557 0297 Maryland
> 505 699 1632 Cell Phone
Re: Initialising an ao record from a constant DOL Bob Dalesio
Re: Initialising an ao record from a constant DOL Luedeke Andreas
Prev: Re: Initialising an ao record from a constant DOL Bob Dalesio
Next: Re: Initialising an ao record from a constant DOL Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initialising an ao record from a constant DOL David Maden
Next: Re: Initialising an ao record from a constant DOL Bob Dalesio
