1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialising an ao record from a constant DOL
To: "Owens, PH (Peter)" <[email protected]>
Cc: "'Bob Dalesio'" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 23 Apr 2004 16:34:33 +0200
Owens, PH (Peter) wrote:
Even if a device did support this bumpless
changeover feature I would still have thought
that it should be overwritten by a constant DOL
just as it is if DOL is a link.
I understand this is a "feature" of onrlSerial.
At least this problem does not exist for "Soft Channel"
support.
An easy and clean way to solve this would be, to
configure this feature from the link field.
Andreas
RE: Initialising an ao record from a constant DOL Owens, PH (Peter)
Prev: RE: Initialising an ao record from a constant DOL Owens, PH (Peter)
Next: Re: Initialising an ao record from a constant DOL Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initialising an ao record from a constant DOL Benjamin Franksen
Next: RE: Initialising an ao record from a constant DOL Owens, PH (Peter)
