1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialising an ao record from a constant DOL
To: [email protected]
Date: Mon, 26 Apr 2004 11:35:19 +0200
Hi Andrew,
sorry for the confusion. I mixed up the meanings of 0 and 2 when
returned from ao device support init_record. I thought Pete wanted to
disable bumpless reboot and instead use the value that was specified in
DOL field.
Ben
Re: Initialising an ao record from a constant DOL Bob Dalesio
Re: Initialising an ao record from a constant DOL Benjamin Franksen
Re: Initialising an ao record from a constant DOL Andrew Johnson
Prev: Re: Initialising an ao record from a constant DOL Andrew Johnson
Next: RE: Initialising an ao record from a constant DOL Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Initialising an ao record from a constant DOL Luedeke Andreas
