On Friday 23 April 2004 16:45, Andrew Johnson wrote:
> It looks to me like Pete's device support is returning a 0 from its
> init_record routine, when it should be returning a 2 as it hasn't properly
> set the RVAL field.
> I think that explains the problem and where the correct solution needs to
> go - in ornlSerial. I'd suggest checking all of its output device
> supports which I believe should all do the same thing.
As i understood it, the device support returns 0 by purpose in order to enable
bumpless reboot and what Pete wants is to override this behavior with a
constant in DOL. As Bob said this is not possible at the moment. But i think
it should be possible to change the ao record support so that if DOL is
defined with some constant value then this value takes precedence over any
value return from the device support's init_record for bumpless reboot.
Ben
- Re: Initialising an ao record from a constant DOL Andrew Johnson
- Re: Initialising an ao record from a constant DOL Bob Dalesio
EPICS collaboration meeting presentations Bob Dalesio
Vacancy at APS John Maclean
<2004>
2025
2026
<2004>
2025
2026
