Thanks for the help.
Getting the ornlSerial device support init routine to return 2
does indeed solve the problem.
Questions:
1. Is this 2 symbolically defined in a header file somewhere?
2. Where is the best place to find a "How to write device support" manual?
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 23 April 2004 15:46
> To: Bob Dalesio
> Cc: Owens, PH (Peter); [email protected]
> Subject: Re: Initialising an ao record from a constant DOL
> It looks to me like Pete's device support is returning a 0 from its
> init_record routine, when it should be returning a 2 as it
> hasn't properly
> set the RVAL field.
> I think that explains the problem and where the correct
> solution needs to
> go - in ornlSerial. I'd suggest checking all of its output device
> supports which I believe should all do the same thing.
- Re: Initialising an ao record from a constant DOL Andrew Johnson
Re: Initialising an ao record from a constant DOL Benjamin Franksen
<2004>
2025
2026
Re: Initialising an ao record from a constant DOL Luedeke Andreas
<2004>
2025
2026
