Thank you for the reminder about reading the release notes. I was able
to build my extensions by setting COMPAT_TOOLS_313=YES.
Thanks to everyone for the assistance.
Geoff
Ralph Lange wrote:
Note that there's also a second variable called
COMPAT_313
that can be set to YES to allow 3.13 IOC applications to be built.
Btw: All of this is explicitly covered in the 3.14.5 Release Notes, but
I know that such information always has a strong tendency to be in the
one place that you don't look for it.
Cheers,
Ralph
"Andy" == Andy Foster <[email protected]> writes:
> Geoff,
> I had a problem with "makeMakefile.pl" not being copied to
> the bin directory.
> It turned out to be because I hadn't set:
> in
> "base/configure/CONFIG_SITE"
> This is a change introduced in the configuration files
> between releases 3.14.4 and 3.14.5.
> Not sure whether this will solve all of your problems
> but hope it helps anyway.
> Cheers,
> Andy
> On Fri, 14 May 2004, Geoff Savage wrote:
>> Hi,
>> As the subject says I am attempting to build R3.13 extensions with
>> R3.14.5. I am following the instructions at
>> http://www.aps.anl.gov/epics/modules/base/R3-14/5-docs/BuildingR3.13ExtensionsWithR3.14.html
>> with no success. Here are the error messages.
>> [savage@d0ol30 extensions]$ gmake
>> stat(): No such file or directory at ./config/fullPathName.pl line 6
- building R3.13 extensions with R3.14.5 Geoff Savage
- Re: building R3.13 extensions with R3.14.5 Andy Foster
- Re: building R3.13 extensions with R3.14.5 Ralph Lange
EPICS indexed by the FSF/UNESCO Free Software Directory Jeff Hill
<2004>
2025
2026
RTEMS BSP for MVME5500 Kate Feng
<2004>
2025
2026
