Consider this templates: test.template record(calc,"$(NAME):rdbk") {
field(DESC,"calculation")
field(SCAN,".5 second")
field(CALC,"A")
field(INPA,"$(NAME):rd .PP.NMS")
field(HOPR,"$(HOPR)")
field(LOPR,"$(LOPR)")
}test.template record(ai,"$(NAME):$(SNAME):rd") {
field(DESC,"position readback")
}and this substitution file: file test.template {
{ NAME="X", HOPR="9", LOPR="1"}
file test1.template {
{ NAME="Y" }
}Remark: The substittutions $HOPR and $LOPR are used in both files, but in the .substitution files it is forgotten for the second file, test1.template. After the run of make dbloadTemplat will create: record(calc,"X:rdbk") {
field(CALC,"A")
field(INPA,"X:rd .PP.NMS")
field(HOPR,"9")
field(LOPR,"1")
record(ai,"Y:$(SNAME):rd") {
field(HOPR,"9")
field(LOPR,"1")
}HOPR and LOPR will be set in both records, so the last defined value from the former substituted file will be used for the actual file. This is not correct. Grüssle Bernhard PS: the work I did when I found this was not such an easy EPICS database. -- ------------------------------------------------------------------- -- [email protected] ----------- Bessy Gmbh ----------------- -- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 - -------------------------------------- 12489 Berlin ---------------
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
