1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: help building StripTool and caSnooper under EPICS R3.14.6
To: "tech-talk (E-mail)" <[email protected]>
Date: Mon, 31 May 2004 23:13:10 -1000
I've successfully built EPICS R3.14.6 for solaris-sparc-gnu and am
attempting to build caSnooper and StripTool under it.  However I've run into
the following error building them:
gmake[4]: Entering directory
`/home/ktsubota/epics/extensions/src/StripTool/O.solaris-sparc-gnu'
g++ -ansi -pedantic -Wtraditional -o StripTool -O3  -Wall
-Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion
-Wstrict-prototypes -Wpointer-arith -Winline    -fPIC -D_REENTRANT  -DUNIX
-DEXPL_TEMPL -I. -I.. -I/usr/dt/include -I/usr/openwin/include
-I/usr/openwin/include -I/usr/openwin/include -I../../../include/os/solaris
-I../../../include -I/home/ktsubota/epics/base-3.14.6/include/os/solaris
-I/home/ktsubota/epics/base-3.14.6/include     -DUSE_MOTIF -DUSE_CLUES
-DUSE_XMU -DSOLARIS=8  -D_POSIX_C_SOURCE=199506L -D__EXTENSIONS__
-L/home/ktsubota/epics/base-3.14.6/lib/solaris-sparc-gnu/ -L/usr/dt/lib/
-L/usr/openwin/lib/  -mt
-R/home/ktsubota/epics/base-3.14.6/lib/solaris-sparc-gnu
-R../../../lib/solaris-sparc-gnu StripHistoryAR+ArR.o StripConfig.o
StripCurve.o Strip.o StripDialog.o StripDataSource.o StripGraph.o
StripMisc.o cColorManager.o ColorDialog.o StripTool.o StripCA.o jlAxis.o
jlLegend.o ComboBox.o FastLabel.o Tabs.o x_rotate.o rotated.o browserHelp.o
LiteClue.o main_c.o getHistory.o     -lca -lCom -lXm -lXt -lXmu -lX11
-lsocket -lnsl -lposix4 -lpthread -lCrun  -lm
ld: fatal: library -lCrun: not found
ld: fatal: File processing errors. No output written to StripTool
collect2: ld returned 1 exit status
gmake[4]: *** [StripTool] Error 1
Where do I get the Crun library from?  I get this error for caSnooper as
well.
Also to get this far for StripTool, I had to specify NO for HAVE_XPM and
USE_SDDS in Makefile.Host.
Is this normal for solaris-sparc-gnu architecture?
Thanks in advance.
Kevin
Prev: RE: EtherIP & AB PLC's Rarback, Harvey
Next: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CVS vulnerability Jeff Hill
