Hopefully, none of our colleagues have exported the port of a CVS server
through their firewall. An example setup which might be likely to experience
malicious abuse would be allowing direct read only anonymous access to a CVS
server. See attached.
Jeff
>>-----BEGIN PGP SIGNED MESSAGE-----
>>A DOE site reported that one of their systems was quite likely
>>compromised through a recently announced CVS vulnerability. They
>>discovered this because a second DOE site reported seeing probes for
>>the vulnerability by several foreign IP addresses. Those IP addresses
>>and the UTC times that were seen at the second site
>>are:
>>May 23 17:43:29 62.87.235.95
>>May 23 19:03:24 217.96.8.158
>>May 23 20:09:53 217.120.30.217
>>May 23 20:24:35 218.42.151.179 *
>>May 23 20:49:28 80.139.250.197 *
>>May 24 10:53:41 82.149.228.89 *
>>May 24 10:59:04 82.149.228.89 *
>>May 24 13:42:48 213.149.96.50
>>May 24 14:11:09 217.120.30.217
>>May 24 16:34:46 62.80.126.39
>>The three IP addresses with "*" were also seen on the compromised
>>system at the first DOE site. The second site also reported that the
>>sequence of CVSROOT directories tried is precisely the sequence in the
>>exploit code which can be seen at
>>http://packetstormsecurity.nl/0405-exploits/cvs_linux_freebsd_HEAP.c
>>CIAC suggests that the DOE sites look for suspicious connections with
>>these and other IP addresses to their CVS servers. Vulnerable servers
>>can be patched according to CIAC Bulletin O-147: Linux CVS Server Heap
>>Overflow Vulnerability.
>>________________________________________________________________________
>> The Computer Incident Advisory Capability
>> ___ __ __ _ ___
>> \___ __|__ /___\ \___
Jeff
Jeffrey O. Hill Mail [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA Fax 505 665 5107
EtherIP & AB PLC's D Wetherholt
RE: EtherIP & AB PLC's Rarback, Harvey
<2004>
2025
2026
help building StripTool and caSnooper under EPICS R3.14.6 Kevin Tsubota
<2004>
2025
2026
