1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time
Cc: kuner <[email protected]>, [email protected]
Date: Thu, 03 Jun 2004 16:44:45 +0200
Mark Rivers wrote:
Bernhard Kuner wrote:
something like this:
file test.template {
pattern{ NAME, HOPR="9", LOPR="1", MDEL="0.1"}
I really like this suggestion.
One problem with template files now is that it is real hassle if one
wants to add an additional subsitution parameter. Suppose test.template
above does not currently support the MDEL parameter, but I want to add
it. At present, if I add it, then I have to find every substitution
file that references test.template and update it to add MDEL.
With Bernhard's suggestion, this would not be necessary. I could define
a default value for that new parameter, which would be the same as the
previous default value for that field in test.template, or if it was not
defined there, then the default value in the record. Existing
substitution files will work as they always did, but new ones can now
use the MDEL parameter.
Mark Rivers
If you specify default values in the "pattern" line, then you still have to change all substitution files that use your extended template. Although it becomes easier, because you just need to change the "pattern" lines.
To keep an extended template backward compatible, you would need to
specify the default values in the template file.
Two possibilities to specify default values would be:
a) where you use a substitution variable: "$(MDEL=0.1)"
b) in a comment line with a new keyword: #default{MDEL="0.1"}
+ example.subs:
 {NAME=X, MDEL=1}
 {NAME=Y}
+ test.template of type a):
record(ai,"$(NAME)") {
 field(MDEL,"$(MDEL=0.1)")
+ test.template of type b):
 field(MDEL,"$(MDEL)")
+ dbLoadTemplate example.subs (in both cases)
record(ai,"X") {
 field(MDEL,"1")
record(ai,"Y") {
 field(MDEL,"0.1")
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
mailto:[email protected], http://people.web.psi.ch/luedeke
RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Mark Rivers
Prev: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Ralph Lange
Next: bug and fix in iocCore Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Mark Rivers
Next: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Mark Rivers
