> If you specify default values in the "pattern" line, then you
> still have to change all substitution files that use your extended
> template. Although it becomes easier, because you just need to change
the
> "pattern" lines.
> To keep an extended template backward compatible, you would need to
> specify the default values in the template file.
> Two possibilities to specify default values would be:
> a) where you use a substitution variable: "$(MDEL=0.1)"
> b) in a comment line with a new keyword: #default{MDEL="0.1"}
I guess I misunderstood Bernhard's suggestion. I would like to add the
defaults to the template file as you suggest, so that it is not
necessary to mofify the substitutions files.
bug and fix in iocCore Dirk Zimoch
Bugs in 3.14.5 Kate Feng
<2004>
2025
2026
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Luedeke Andreas
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
<2004>
2025
2026
