1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bugs in 3.14.5 (recall)
To: Eric Norum <[email protected]>, [email protected]
Date: Fri, 04 Jun 2004 16:39:00 -0400
Kate Feng wrote:
> Eric Norum wrote:
> > Kate Feng wrote:
> > > 385c385
> > > <         delay = 1;
> > >>        delay = 0;
> > I think that the existing behaviour matches the semantics described in the
> > application developer's guide.
> I guess I should have mentioned that it was a workaround, but
> not a fix.  It turns out that it is not a good call.
> The IOC hung at iocInit() after we tried to add the eighth
> motor controller cards in the crate running RTEMS-mvme2307.
> Further tests showed that,  as a wokaround,one clock tick of delay is
> needed between the end of the scaler_init_record()
> and before it entered the oms_init_record().
As I am sending this,  I  think it is possible that the motor cards was not
in a ready state for the oms_init_record()/motor_init_record_com().
Kate
Bugs in 3.14.5 Kate Feng
Re: Bugs in 3.14.5 Eric Norum
Re: Bugs in 3.14.5 Kate Feng
Prev: Re: Bugs in 3.14.5 Kate Feng
Next: Question on transition modules Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Bugs in 3.14.5 Mark Rivers
