1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bugs in 3.14.5
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Fri, 04 Jun 2004 16:23:05 -0400
Eric Norum wrote:
> Kate Feng wrote:
> > 385c385
> > <         delay = 1;
> >>        delay = 0;
> I think that the existing behaviour matches the semantics described in the
> application developer's guide.
I guess I should have mentioned that it was a workaround, but
not a fix.  It turns out that it is not a good call.
The IOC hung at iocInit() after we tried to add the eighth
motor controller cards in the crate running RTEMS-mvme2307.
Further tests showed that,  as a wokaround,one clock tick of delay is
needed between the end of the scaler_init_record()
and before it entered the oms_init_record().  At this point, it seems
that the bug  might not be  even RTEMS related.
rtems_task_wake_after(0) works fine.
We were able to  load eight motor cards in one crate running 3.13.x vxWorks.
I guess a better question is :did anyone load eight OMS58 motor cards
in one crate running 3.14.x /vxWorks ?  We do not have the updated version
of vxWorks for the mvme2307 to test 3.14.x.
The final test I did is based on the EPICS 3.14.5 /RTEMS, and SynApp 3.14.5.
I do not have enough time to try 3.14.6 since I have to turn in
the eight motor cards for operations.
Kate
Re: Bugs in 3.14.5 (recall) Kate Feng
Bugs in 3.14.5 Kate Feng
Re: Bugs in 3.14.5 Eric Norum
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Benjamin Franksen
Next: Re: Bugs in 3.14.5 (recall) Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bugs in 3.14.5 Eric Norum
