Subject: |
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time |
Benjamin Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 4 Jun 2004 21:25:53 +0200 |
On Friday 04 June 2004 15:09, Ralph Lange wrote:
> o Allowing $(name=default) in the template database, as the first level
> of default values.
> (-> per template)
> o Allowing a line like
> default{SCAN=Passive, HOPR=9, LOPR=1, ADEL=0.5, MDEL=0.1}
> in the head of a file entry in a substitution file, mutually
> exclusive with the unchanged pattern{} keyword used for tabular
> material - to avoid messy incomprehensive tables.
I can't see a conflict between pattern{} style instantiation and default{}
definitions. Of course, default{} should appear before pattern (if at all).
For the case that a <name> is mentioned inside the pattern{} as well as
inside the default{}, two solutions make sense: First, disallow it. Second,
the values in the table override the default, effectively disabling it. I
prefer the second version because it is more uniform i.e. the same behavior
as in the non-pattern case. NB: Allowing <name>=<default-value> inside a
pattern{} would make sense only if one could remove the values for this
<name> from the table which would destroy the 1:1 correspondence between
columns and is therefore not a good idea, IMO.
> The default specifications on this line would override the default
> definitions in the template database.
> (-> per use)
> o Allowing the usual unchanged macro substitutions in the lines of the
> substitution file.
> (-> per instance)
> Should fit any of the mentioned cases without implying anything on
> anyone, shouldn't it?
With the exception of above remark, I second that.
Ben
- Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
- Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Ralph Lange
Re: Bugs in 3.14.5 Kate Feng
<2004>
2025
2026
organizing extensions/applications Geoff Savage
<2004>
2025
2026
