Hi Ron,
IN the new Wiener crates we place the transition modules in the back of the crates. However,
since this is not possible in the older VME crates, just use one of the available slots
in the crate. I belive there is an empty slot next to the cpu in the BIC.
If the crate is full after installing the transition modules, make sure that
cooling in the crates is sufficient. Ask John Dusatko or someone in hw to check
this out for you. I imagine that cooling will be sufficient as the VME crate
used for the BIC application is now in a cooled rack environment.
- Kristi
-----Original Message-----
To: [email protected]
Sent: 6/4/2004 3:41 PM
Subject: Question on transition modules
In our group at SLAC we are using some MV167/MV177 and some PPC 2700 VME
controllers. Each class has its own transition module. Rumor has it that
using the wrong transition module can damage the CPU. Since there seem
to be active components on the transition module, this is entirely
believable.
We also have some older VME crates with homebrew "transitions"; these
crates all currently have MV167/MV177 modules. The interface is entirely
passive, with connections to the backplane and to external connectors
for one console port and ethernet. The advantage of these crates is that
one can actually get modules in without a mallet, and that many are
available. The layout of the crate precludes using the commercial 2700
transition module without moving the power supply around.
Before I fry an MV2700, I would like to know if this purely passive
"transition" solution has the possibility of actually harming the CPU.
Can anyone explain the caveats of these transition issues, please!
Thank you in advance.
/Ron Chestnut
RE: Question on transition modules Mark Rivers
Re: EPICS Base Release 3.14.6 Dirk Zimoch
<2004>
2025
2026
[no subject] sunxy
<2004>
2025
2026
