Thanks for your message,
We are aware of this problem. I have attached the latest version of the
impacted source file.
Jeff
> -----Original Message-----
> From: guobao shen [mailto:[email protected]]
> Sent: Wednesday, June 09, 2004 11:50 PM
> To: [email protected]
> Subject: blockingSockTest.cpp Compiling error
> Hello everyone,
> When I try to compile R3.14.6 against Tornado2.2/vxWorks5.5, there are 2
> errors about
> the socket functions, connect() and bind() in blockingSockTest.cpp file.
> /epics/Tornado2.2/host/sun4-solaris2/bin/ccppc -c -D_POSIX_SOURCE
> -DCPU=PPC604 -DvxWorks -i
> nclude /epics/Tornado2.2/
> target/h/vxWorks.h -ansi -O3 -Wall -mcpu=604 -mstrict-align -fno-
> implicit-templates -fno-bu
> iltin -I. -I.. -I../../.
> .../../include/os/vxWorks -I../../../../include -
> I/epics/Tornado2.2/target/h
> ..../blockingSockTest.cpp
> ..../blockingSockTest.cpp: In method `clientCircuit::clientCircuit(const
> address &)':
> ..../blockingSockTest.cpp:130: passing `const sockaddr *' as argument 2
> of `connect(int, sockaddr *,
> int)' discards qualifiers
> ..../blockingSockTest.cpp: In method `server::server(const address &)':
> ..../blockingSockTest.cpp:160: passing `const sockaddr *' as argument 2
> of `bind(int, sockaddr *,
> ..../blockingSockTest.cpp: In function `void blockingSockTest()':
> ..../blockingSockTest.cpp:210: warning: unused variable `class server
> srv'
> gnumake[3]: *** [blockingSockTest.o] Error 1
> gnumake[3]: Leaving directory `/epics/base-
> 3.14.6/src/libCom/test/O.vxWorks-ppc604'
> gnumake[2]: *** [install.vxWorks-ppc604] Error 2
> gnumake[2]: Leaving directory `/epics/base-3.14.6/src/libCom/test'
> gnumake[1]: *** [libCom/test.install] Error 2
> gnumake[1]: Leaving directory `/epics/base-3.14.6/src'
> gnumake: *** [src.install] Error 2
> So should it be like the following?
> line 130:
> int status = ::connect (
> this->sock,(struct sockaddr *) & addrIn.sa, sizeof ( addrIn ) );
> line 160:
> int status = bind ( this->sock,
> Thank you very much!
> Guobao Shen
> KEKB Control Group
> J-PARC Control Group
#include <string.h>
#include <assert.h>
#include "osiSock.h"
#include "osiWireFormat.h"
#include "epicsThread.h"
#include "epicsSignal.h"
union address {
struct sockaddr_in ia;
struct sockaddr sa;
class circuit {
public:
circuit ( SOCKET );
void recvTest ();
void shutdown ();
void signal ();
void close ();
bool recvWakeupDetected () const;
bool sendWakeupDetected () const;
virtual const char * pName () = 0;
protected:
SOCKET sock;
epicsThreadId id;
bool recvWakeup;
bool sendWakeup;
class serverCircuit : public circuit {
public:
serverCircuit ( SOCKET );
private:
const char * pName ();
class clientCircuit : public circuit {
public:
clientCircuit ( const address & );
private:
class server {
public:
server ( const address & );
void daemon ();
protected:
SOCKET sock;
epicsThreadId id;
bool exit;
circuit::circuit ( SOCKET sockIn ) :
sock ( sockIn ),
id ( 0 ),
recvWakeup ( false ),
sendWakeup ( false )
assert ( this->sock != INVALID_SOCKET );
bool circuit::recvWakeupDetected () const
return this->recvWakeup;
bool circuit::sendWakeupDetected () const
return this->sendWakeup;
void circuit::shutdown ()
int status = ::shutdown ( this->sock, SHUT_RDWR );
assert ( status == 0 );
void circuit::signal ()
epicsSignalRaiseSigAlarm ( this->id );
void circuit::close ()
epicsSocketDestroy ( this->sock );
void circuit::recvTest ()
epicsSignalInstallSigAlarmIgnore ();
char buf [1];
while ( true ) {
int status = recv ( this->sock,
buf, (int) sizeof ( buf ), 0 );
if ( status == 0 ) {
printf ( "%s: %s was disconnected\n",
__FILE__, this->pName () );
this->recvWakeup = true;
break;
else if ( status > 0 ) {
printf ( "%s: client received %i characters\n",
__FILE__, status );
else {
char sockErrBuf[64];
epicsSocketConvertErrnoToString (
sockErrBuf, sizeof ( sockErrBuf ) );
printf ( "%s: %s socket recv() error was \"%s\"\n",
__FILE__, this->pName (), sockErrBuf );
break;
void socketRecvTest ( void * pParm )
circuit * pCir = reinterpret_cast < circuit * > ( pParm );
pCir->recvTest ();
clientCircuit::clientCircuit ( const address & addrIn ) :
circuit ( epicsSocketCreate ( AF_INET, SOCK_STREAM, IPPROTO_TCP ) )
address tmpAddr = addrIn;
this->sock, & tmpAddr.sa, sizeof ( tmpAddr ) );
circuit * pCir = this;
this->id = epicsThreadCreate (
"client circuit", epicsThreadPriorityMedium,
epicsThreadGetStackSize(epicsThreadStackMedium),
socketRecvTest, pCir );
assert ( this->id );
const char * clientCircuit::pName ()
return "client circuit";
void serverDaemon ( void * pParam ) {
server * pSrv = reinterpret_cast < server * > ( pParam );
pSrv->daemon ();
server::server ( const address & addrIn ) :
sock ( epicsSocketCreate ( AF_INET, SOCK_STREAM, IPPROTO_TCP ) ),
id ( 0 ), exit ( false )
// setup server side
status = listen ( this->sock, 10 );
"server daemon", epicsThreadPriorityMedium,
serverDaemon, this );
void server::daemon ()
while ( ! this->exit ) {
// accept client side
address addr;
osiSocklen_t addressSize = sizeof ( addr );
SOCKET ns = accept ( this->sock,
& addr.sa, & addressSize );
assert ( ns != INVALID_SOCKET );
new serverCircuit ( ns );
serverCircuit::serverCircuit ( SOCKET sockIn ) :
circuit ( sockIn )
epicsThreadId id = epicsThreadCreate (
"server circuit", epicsThreadPriorityMedium,
assert ( id );
const char * serverCircuit::pName ()
return "server circuit";
void blockingSockTest ()
address addr;
memset ( (char *) & addr, 0, sizeof ( addr ) );
addr.ia.sin_family = AF_INET;
addr.ia.sin_addr.s_addr = epicsHTON32 ( INADDR_LOOPBACK );
//addr.ia.sin_addr.s_addr = epicsHTON32 ( 0x80A5A07F );
addr.ia.sin_port = epicsHTON16 ( 5064 ); // CA
server srv ( addr );
clientCircuit client ( addr );
epicsThreadSleep ( 1.0 );
assert ( ! client.recvWakeupDetected () );
client.shutdown ();
const char * pStr = "esscimqi_?????";
if ( client.recvWakeupDetected () ) {
pStr = "esscimqi_socketBothShutdownRequired";
else {
client.signal ();
pStr = "esscimqi_socketSigAlarmRequired";
else {
client.close ();
pStr = "esscimqi_socketCloseRequired";
else {
printf ( "The local OS behaves like \"%s\".\n", pStr );
switch ( epicsSocketSystemCallInterruptMechanismQuery() ) {
case esscimqi_socketCloseRequired:
break;
case esscimqi_socketBothShutdownRequired:
break;
case esscimqi_socketSigAlarmRequired:
break;
printf ( "The epicsSocketSystemCallInterruptMechanismQuery() function returns\n\"%s\".\n",
pStr );
- blockingSockTest.cpp Compiling error guobao shen
RE: multiple virtual IOCs with single CA server? Jeff Hill
<2004>
2025
2026
Re: blockingSockTest.cpp Compiling error Andrew Johnson
<2004>
2025
2026
