1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multiple virtual IOCs with single CA server?
To: "'Dirk Zimoch'" <[email protected]>
Cc: "'Laznovsky, Michael'" <[email protected]>, "'tech talk'" <[email protected]>
Date: Thu, 10 Jun 2004 08:54:29 -0600
> On modern Linux kernels, it is also possible to create
> "virtual network interfaces", i.e. to assign more that one
> IP address to the same physical network interface. It should
> be possible to run every IOC with its own virtual
> interface/addess/hostname. But I have not tried that yet.
An interesting idea. Please send a summary of your experiences if you try
this.
Jeff
> Dirk
> Jeff Hill wrote:
> > Hi Mike,
> > There is a way to do this, but there are also some significant
> limitations.
> > They are documented in the CA reference manual, and I have attached an
> > excerpt. A possible solution to this problem would be to add
> multicasting
> > support to the CA server. This probably isn't going to be that hard to
> do,
> > but so far there haven't been that many requests for multiple servers
> on the
> > same system.
> > Of course, another possibility will be to just combine N IOCs into one.
> > Jeff
> > Unicast Addresses in the EPICS_CA_ADDR_LIST Does not Reliably Contact
> > Servers Sharing the Same UDP Port on the Same Host
> > Two servers can run on the same host with the same server port number,
> but
> > there are restrictions. If the host has a modern IP kernel it is
> possible to
> > have two or more servers share the same UDP port. It is not possible
> for
> > these servers to run on the same host using the same TCP port. If the
> CA
> > server library detects that a server is attempting to start on the
> same port
> > as an existing CA server then both servers will use the same UDP port,
> and
> > the 2nd server will be allocated an ephemeral TCP port. Clients can be
> > configured to use the same port number for both servers. They will
> locate
> > the 2nd server via the shared UDP port, and transparently connect to
> the 2nd
> > server's ephemeral TCP port. Be aware however that If there are two
> server's
> > running on the same host sharing the same UDP port then they will both
> > receive UDP search requests sent as broadcasts, but unfortunately (due
> to a
> > weakness of most IP kernel implementations) only one of the servers
> will
> > typically receive UDP search requests sent to unicast addresses (i.e.
> a
> > single specific host's ip address).
> >>-----Original Message-----
> >>From: Laznovsky, Michael [mailto:[email protected]]
> >>Sent: Tuesday, June 08, 2004 3:56 PM
> >>To: tech talk
> >>Subject: multiple virtual IOCs with single CA server?
> >>Greetings- when running multiple virtual (i.e. target=solaris) IOCs on
> >>one host, is it possible to configure a single channel access server
> to
> >>provide all the PVs, rather than having multiple servers all using
> >>different ports?
> >>I can see that difficulties, given that the IOCs run as independent
> Unix
> >>processes... might an alternative be to daisy-chain the CA servers
> >>somehow
> >>on the same ports?  Just speculating here.
> >>thanks,
> >>Mike
> >>Michael P. Laznovsky
> >>Application Software Developer, ESD                     ofc: (650)
> 926-
> >>2924
> >>Stanford Linear Accelerator Center, MS-46               fax: (650)
> 926-
> >>3515
> >>2575 Sand Hill Road, Menlo Park CA 94025 USA
> >>http://www.slac.stanford.edu
> Dr. Dirk Zimoch
> Swiss Light Source
> Paul Scherrer Institut
> Computing and Controls
> phone +41 56 310 5182
> fax   +41 56 310 4413
Re: multiple virtual IOCs with single CA server? Jens Eden
Re: multiple virtual IOCs with single CA server? Dirk Zimoch
Prev: RE: blockingSockTest.cpp Compiling error Jeff Hill
Next: Re: blockingSockTest.cpp Compiling error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: blockingSockTest.cpp Compiling error Andrew Johnson
Next: Re: multiple virtual IOCs with single CA server? Jens Eden
