1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: multiple virtual IOCs with single CA server?
To: [email protected]
Date: Tue, 22 Jun 2004 11:58:35 +0200
>>Dirk Zimoch wrote:
On modern Linux kernels, it is also possible to create "virtual network interfaces", i.e. to assign more that one IP address to the same physical network interface. It should be possible to run every IOC with its own virtual interface/addess/hostname. But I have not tried that yet.
Jeff Hill wrote: An interesting idea. Please send a summary of your experiences if you try this.
We are running an EPICS Gateway in a Linux Heartbeat (http://linux-ha.org/) configuration since a few months. The gateway process runs on a virtual network interface on one linux server. If the server dies, the gateway process fails over to another linux server using the same IP address (again on a virtual network interface). While switching from one server to the other the CA-clients loose connection, but reconnect after a few seconds, as soon as the new gateway process is up.
We occasionally have gateway problems with old CA-clients running on VMS-Systems,
but I don't believe this is related to the virtual network interface.
Jens
RE: multiple virtual IOCs with single CA server? Jeff Hill
Prev: Re: Compiling Gateway 2.0.0.0.Beta8 Jens Eden
Next: RE: multiple virtual IOCs with single CA server? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: multiple virtual IOCs with single CA server? Jeff Hill
