1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MVME-5100 choices
To: Steven Hartman <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 25 Jun 2004 15:23:09 -0400
I have been working on an SNS BSP for the 5100.  We have the model with
the 7410 processor and we have been able to run epics on it.  You
probably can run epics on the stock kernel but I would recommend at
least increasing the network stack and enabling bus errors.  Andrew
probably has some ideas and I also have some working code for that.
There are some compiler issues.  The compiler they ship won't build
everything and you can't use the compiler from T2.0.2.
-----Original Message-----
Sent: Friday, June 25, 2004 1:29 PM
To: EPICS tech-talk
Subject: MVME-5100 choices
I am about to order some MVME-5100 single board computers. I notice that
there are two different processors available for this family: the
MVME5100-016x with a 450 MHz MPC750, and the MVME5110-2x6x with a 400 or
500 MHz MPC7410.
Are either of these processors acceptable (tested) with EPICS on
VxWorks?
Any strong recommendations of one over the other?
I will be using Tornado-2.2.1/VxWorks-5.5, with EPICS R.3.13.10
initially,
but perhaps a 3.14 version later.
Thank you,
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Prev: Next EPICS Meeting - Response Needed Bob Dalesio
Next: virtual circuit disconnect Zheng Lifang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MVME-5100 choices Steven Hartman
Next: Next EPICS Meeting - Response Needed Bob Dalesio
