Hi Lifang,
you shouldn't have to set the EPICS_CA_ADDR_LIST in that case, as using
a broadcast on the local network is the default behaviour when a CA
clients wants to connect.
Do you get the same results if you don't set the variable - neither on
the PC nor on the IOC?
Ralph
>>>>> "Zheng" == Zheng Lifang <[email protected]> writes:
> Hi All,
> We set 192.168.26.n as our control subnet. A PC/Redhat9.0 (with its IP 192.168.26.2) runs edm, and its netmask is set to ffffff00 . The IOC IP address is set to 192.168.26.11:ffffff00 in the boot parameter.
> The IOC downloads vxWorks and EPICS normally from PC/Redhat. In st.cmd there is putenv("EPICS_CA_ADDR_LIST=192.168.26.255") before iocInit. Also in PC/Linux I set EPICS_CA_ADDR_LIST=192.168.26.255 in .bash_profile .
> But sometime edm can't connect to IOC, and displays the following messages:
> CA.Client.Exception..........................
> Warning: "Virtual circuit disconnect"
> Context: "192.168.26.11:5064"
> Source File: ../cac.cpp line 1147
> Current Time: Mon Jun 28 2004 16:37:11.282870000
> Where do I set incorrectly or should pay attention more?
> Regards,
> Lifang
- RE: virtual circuit disconnect Jeff Hill
- caRepeater working practices Simon Rees
- virtual circuit disconnect Zheng Lifang
<2004>
2025
2026
<2004>
2025
2026
