1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Fwd: Re: EPICS naming services]
To: "'[email protected]'" <[email protected]>
Date: Fri, 02 Jul 2004 18:28:39 +0200
Rowland, J (James) wrote:
Hello,
Does anyone have a naming service for EPICS that allows querys of all PV
names, build time and currently active?
I would like to be able to browse all channels in the system, and see
whether they are active on an IOC, designated as a channel in my system but
not currently running, or present on an IOC but unknown (hopefully not).
at the SLS we upload the channels at boot time from the IOC to an oracle table. This is done by a perl script running on the boot pc started by the ioc using rsh, reading a file generated before by the IOC using the dbl command. Not quite the portability you would like to have for epics 3.14 applications: you need to save a file from the IOC and you need to have an rsh mechanism.
Anyway, if you're interested, have a look at:
http://www.lnf.infn.it/conference/pcapac2002/TALK/WE-06/WE-06_talk.pdf
http://www.lnf.infn.it/conference/pcapac2002/TALK/WE-06/WE-06.pdf
http://www.diamond.ac.uk/Activities/EPICS/Thursday_PM/ChannelManagement2002.ppt
I can send you a zip with all the scripts and some documentation,
if you think it is worth looking into it.
If not, are there any thoughts regarding standard directory services
interfaces (COS naming, LDAP) etc. that would be acceptable to the
community. I realise that this has been an issue for some time.
If you want to make a proposal I would really like to read it :-)
Kind Regards
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
mailto:[email protected], http://people.web.psi.ch/luedeke
Re: EPICS naming services Andrew Johnson
Prev: EPICS naming services Rowland, J (James)
Next: Re: EPICS naming services Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS naming services Allison, Stephanie
