The rsh mechanism is not essential if you arrange to have a program running on the fileserver which is monitoring all of the dbl output files; when it notices a change it triggers the update sequence. If you're not so worried about short delays you could also just have a cron job that periodically checks for updates. This might also be more appropriate if the processing after a reboot can take a long time to run, as you can limit how often the processing can be started. Bear in mind that the list of PVs (i.e. CA Channel names) is not the same as the output from dbl, which just gives you the record names. A truly omniscient nameserver would also need to know the record type, and the set of publicly accessible field names for that record type on that particular IOC [don't forget that two IOCs that use two different DBD files can have a different set of fields in the same record type, you must make sure you're using the IOC's DBD file to be sure what fields it will have]. A simple way to resolve this would be to dump the DBD file at boot time as well as the dbl output. It should be relatively straightforward to write some IOC-side code which queries the database in memory using dbStaticLib routines, and sends the results directly to the name server; I'm not aware of anyone who has actually implemented something like this though. This code would be able to resolve the field names issue without having to write a parser to extract the DBD filename(s) from the st.cmd file. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
