1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS naming services
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 02 Jul 2004 21:23:51 +0200
Andrew Johnson wrote:
Bear in mind that the list of PVs (i.e. CA Channel names) is not the same as the output from dbl, which just gives you the record names. A truly omniscient nameserver would also need to know the record type, and the set of publicly accessible field names for that record type on that particular IOC [don't forget that two IOCs that use two different DBD files can have a different set of fields in the same record type, you must make sure you're using the IOC's DBD file to be sure what fields it will have]. A simple way to resolve this would be to dump the DBD file at boot time as well as the dbl output.
Of course we put the record type (and description field) to the database, too. At the moment we just upload the dbd file once to the database, since we use the same set of records everywhere. But I agree that it would be more generic and is required for more heterogenious setups, to put one dbd file per IOC to the database. Actually, that is very easy to add, just a minor extension to the "ioc_channels" table.
It should be relatively straightforward to write some IOC-side code which queries the database in memory using dbStaticLib routines, and sends the results directly to the name server; I'm not aware of anyone who has actually implemented something like this though. This code would be able to resolve the field names issue without having to write a parser to extract the DBD filename(s) from the st.cmd file.
Yes, that's a very good idea! I would volunteer to beta test it as soon as there's something to test ;-)
Andreas
BTW: the above is just the "repository of provided channels". We have a second set of scripts to generate a "repository or requested channels". It parses our application launcher for all used commands to retrieve a list of channels required from medm panels, Striptools, Alarmhandler, Archiver and so on. That again should be part of the EPICS applications to provide command line options to just parse their configuration files and return a list of channels and secondary program calls. Or better to write all this to a DB.
[Fwd: Re: EPICS naming services] Luedeke Andreas
Re: EPICS naming services Andrew Johnson
Prev: Re: EPICS naming services Andrew Johnson
Next: RE: EPICS naming services Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS naming services Matthias Clausen
