Hi Kiman
I would strongly recommend getting the tool binaries, especially for someone
starting out with RTEMS. It saved me endless trouble when I first started.
Pete.
-----Original Message-----
To: [email protected]
Cc: [email protected]; [email protected]
Sent: 7/27/2004 12:44 PM
Subject: Re: RTEMSfor MVME5500
[email protected] wrote:
> Hello Kate,
> Mr OH was added on what you attached Makefile.inc and mvme5500.cfg
files.
> Tried again to make utility after cleared before error messages, but
the other error messages are
> ¡°compiled for a little endian system and target is big endian¡±.
> Error Messqges:
> File in wrong format: failed to merge target specific data of file
/opt/rtems/lib/gcc-lib/pp
> c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archive.o)
> /opt/rtems/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/bin/ld:
> ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archures.o):
> ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(bfd.o): compiled
> c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(opncls.o)
> ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(reloc.o): compiled
> He used patch files version are below:
> binutils-2.13.2.1
> gcc-3.2.1
> rtems-ss-20030128
> Did you used different of patch versions for MVME5500 target?
I used gcc-3.2.2. I think gcc-3.2.1 works fine as well.
I downloaded RTEMS4.6.0 from ftp://ftp.rtems.com/pub/rtems/4.6.0/
One should reference Eric Norum's writeup :
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/
in building the GCC tool-chains and RTEMS and in learning
EPICS-RTEMS.
One example I have in building RTEMS is :
mkdir build
cd build
..../rtems-4.6.0/configure -target=ppc-rtems -prefix=/opt/rtems3
--enable-cxx --enable-rdbg
--disable-tests --enable-maintainer-mode --enable-networking
--enable-posix --enable-itron
gmake RTEMS_BSP=mvme2307
gmake RTEMS_BSP=mvme2307 install
Another option is to download the prebuilt binary files from
http://www.rtems.com/..... instead of building it
yourself, which I never tried.
Cheers,
Kate
Re: RTEMSfor MVME5500 Kate Feng
Re: Base on windows Steven . Banks
<2004>
2025
2026
RE: RTEMSfor MVME5500 Elder Matias
Re: Re: GreenSpring TIP810 CANbus system hkm
<2004>
2025
2026
