1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Hardware Support web page suggestion
To: "Kate Feng" <[email protected]>
Cc: "EPICS TechTalk" <[email protected]>
Date: Tue, 17 Aug 2004 13:42:04 -0700
Hi Kate,
> > Here is a suggestion for the EPICS hardware support web
> page.  Right now, it appears that the "Hardware Support: by
> Bus" is gradually turning into "Hardware Support: by Bus
> (OS)" where if OS is not specified, it is assumed to be
> vxWorks.  Could we add a new column for OS that gets filled
> in by the person making the entry?  Thus we could have
> "Hardware Support: by OS" as a fourth option for sorting.
> This means that the same piece of hardware may have several
> entries by different people.
> It is a good suggestion to update the entry.   Also, it became
> painless to port most of the 3.14.x compatible drivers to RTEMS.
> Should we also  add the  3.14.x compatible  entry ?
I think the problem with adding an entry for EPICS version is that when people to upgrade to 3.14, they will forget to edit their entry.  Better for people to go to the link or contact the person listed for versions that are available.
Stephanie
Prev: Re: EPICS Hardware Support web page suggestion Kate Feng
Next: Re: Industry Pack support under RTEMS available? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Announcement: EPICS meeting in Tokai, JAPAN Noboru Yamamoto
