1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Industry Pack support under RTEMS available?
To: Dorothea Wehler <[email protected]>
Cc: EPICS TechTalk <[email protected]>
Date: Tue, 17 Aug 2004 18:56:18 -0700
Dorothea Wehler wrote:
Hello,
may I ask once again for drivers: Is someone using carrier boards on VME-systems running RTEMS together with A/D- and D/A-converter Industry Packs?
We would like to install Industry Packs with 16bit A/D and D/A converters respectively with a throuput of >=100kHz. We shortlist the IP235 from Acromag, A/Dconverter and the IP-ADC-8401 from Hytec.
I've had this working but backed off the Hytec modules because I found a PMC module with more channels/$$ (64 parallel 16-bit ADCs). Also, IP modules are really slow whereas the PMC module sits on the PCI bus allowing for much higher throughput. It features a FIFO and DMA engine. I have RTEMS/EPICS drivers for this card (PMC16AI64SS by general standards inc.)
HTH
-- Till
BTW: note that the hytec IP carrier driver's hotswap support isn't compatible
     with real-time critical applications.
We would be grateful, if someone would be able to make the necessary EPICS driver/device support modules available to us.
Kind regards
Dorothea Wehler
Dr. Dorothea Wehler
Cryoelectra GmbH
Linde 72-74
D-42287 Wuppertal
Germany
Tel: +49 202 / 69824-20
Fax: +49 202 / 69824-40
Industry Pack support under RTEMS available? Dorothea Wehler
Prev: RE: EPICS Hardware Support web page suggestion Allison, Stephanie
Next: Announcement: EPICS meeting in Tokai, JAPAN Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Industry Pack support under RTEMS available? Dorothea Wehler
Next: RE: Industry Pack support under RTEMS available? Mark Rivers
