>> Zhao Zhuo wrote:
>> I'm building base3.14.5 for vxworks-ppc604 on solaris 8 SUN Workstation with gcc.
>> However it showed the following error,why?
>>>>> Andrew Johnson <[email protected]> writes:
> Your errors are actually from building one of the host tools for your
> solaris-sparc-gnu target, and probably mean that you're going to have to
> upgrade the gcc and g++ version on the Solaris workstation. This is
> nothing to do with vxWorks at all, it's related to the compiler that
> builds code to run on Solaris. The upgrade will not cost any money, but
> will have to be done by your Solaris systems administrator.
> What is the version of your current g++ on your workstation? Run this
> command and send us the output:
> /usr/local/bin/g++ --version
> I don't know what the earliest version of gcc that will work is, at APS
> we're now using gcc 3.2 or later on all our systems.
Even though it may not be related to your gcc problem on Solaris:
The latest released version of EPICS base is 3.14.6 - if you do not have
a particular important reason to build a specific version, you should
try to avoid starting something with old versions of things.
I would suggest switching to the latest release (available from the
EPICS web site at APS). It may not solve your gcc problems, but you
probably avoid other issues in 3.14.5 that have been fixed.
Ralph
- Re: building base3.14.5 Zhao Zhuo
- building base3.14.5 Zhao Zhuo
- Re: building base3.14.5 Andrew Johnson
Re: LabVIEW/EPICS Brand Dr. Holger
<2004>
2025
2026
<2004>
2025
2026
