1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Strange errors occur when stalling edm-1-10-0c on redhat 9.0
To: <[email protected]>
Date: Thu, 9 Sep 2004 09:30:30 +0800
Hello All,
I have installed base-3.14.5 on redhat 9.0 successfully, but  errors occur when stalling edm-1-10-0c . In the file ".bash_profile"  are:
# User specific environment and startup programs
PATH=$PATH:$HOME/bin:/control/epics/base-3.14.5/bin/linux-x86:/control/epics/extensions/bin/linux-x86:/control/apps/bin/linux-x86:/usr/java/j2re1.4.1_03/bin
export PATH
export EPICS_HOST_ARCH=linux-x86
export HOST_ARCH=linux-x86
export EPICS_BASE=/control/epics/base-3.14.5
export EPICS_EXTENSIONS=/control/epics/extensions
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/X11R6/lib:$EPICS_BASE/lib/linux-x86:$EPICS_EXTENSIONS/lib/linux-x86:/usr/java/j2re1.4.1_03/lib
export EDMBASE=$EPICS_EXTENSIONS/src/edm
export EDMPVOBJECTS=$EPICS_EXTENSIONS/src/edm/setup
export EDMOBJECTS=$EPICS_EXTENSIONS/src/edm/setup
export EDMHELPFILES=$EPICS_EXTENSIONS/src/edm/helpFiles
export EDMFILES=$EPICS_EXTENSIONS/src/edm/setup
There exist "installEpics.pl" and "makeMakefile.pl" at "$EPICS_BASE/bin/linux-x86".
 Here is the output when  typing "make" at the directory "$EPICS_EXTENSIONS\src\edm":
make -C util buildInstall
make[1]: Entering directory `/control/epics/extensions/src/edm/util'
make -C O.linux-x86 -f .../Makefile.Host T_A=linux-x86 BUILD_TYPE=Host buildInstall
make[2]: Entering directory `/control/epics/extensions/src/edm/util/O.linux-x86'
rm .../*.h
make[3]: Entering directory `/control/epics/extensions/src/edm/util/O.linux-x86'
cp .../sys/linux/os.h .../
cp ../sys/linux/os_objs.h ../
cp ../sys/linux/sys_types.h .../
cp .../sys/linux/os_priv.h ../
cp ../net/linux/ipncl.h ../
cp .../net/linux/ipncl_priv.h ../
cp ../net/linux/ipnsv.h ../
cp .../net/linux/ipnsv_priv.h ../
cp ../net/linux/ipport.h ../
cp .../net/linux/ipport_priv.h ../
cp ../msg/msg.h ../
cp .../msg/msg_priv.h .../
cp ../thread/linux/thread.h ../
cp .../thread/linux/thread_priv.h .../
cp ../iprpc/osf/client_iprpc.h ../
cp .../iprpc/osf/iprpc_priv.h .../
cp ../iprpc/osf/server_iprpc_priv.h ../
cp .../iprpc/osf/client_iprpc_priv.h ../
cp ../iprpc/osf/server_iprpc.h .../
cp .../iprpc/osf/iprpc.h ../
cp ../net/linux/ipnis.h ../
cp .../net/linux/ipnis_priv.h ../
cp ../avl/avl.h ../
cp .../avl/avl_priv.h .../
cp ../crc/crc.h ../
done
make[3]: Leaving directory `/control/epics/extensions/src/edm/util/O.linux-x86'
cp lib114135a4-6f6c-11d3-95bc-00104b8742df.a .../../../../lib/linux-x86
cp lib114135a4-6f6c-11d3-95bc-00104b8742df.so .../../../../lib/linux-x86
make[2]: Leaving directory `/control/epics/extensions/src/edm/util/O.linux-x86'
make[1]: Leaving directory `/control/epics/extensions/src/edm/util'
make -C lib buildInstall
make[1]: Entering directory `/control/epics/extensions/src/edm/lib'
make[2]: Entering directory `/control/epics/extensions/src/edm/lib/O.linux-x86'
make[2]: Nothing to be done for `buildInstall'.
make[2]: Leaving directory `/control/epics/extensions/src/edm/lib/O.linux-x86'
make[1]: Leaving directory `/control/epics/extensions/src/edm/lib'
make -C baselib buildInstall
make[1]: Entering directory `/control/epics/extensions/src/edm/baselib'
make[2]: Entering directory `/control/epics/extensions/src/edm/baselib/O.linux-x86'
make[2]: Leaving directory `/control/epics/extensions/src/edm/baselib/O.linux-x86'
make[1]: Leaving directory `/control/epics/extensions/src/edm/baselib'
make -C edmMain buildInstall
make[1]: Entering directory `/control/epics/extensions/src/edm/edmMain'
Makefile:8: .../Makefile.Host: No such file or directory
make[1]: *** No rule to make target `../Makefile.Host'.  Stop.
make[1]: Leaving directory `/control/epics/extensions/src/edm/edmMain'
make: *** [edmMain.buildInstall] Error 2
It is strange that the file  "Makefile.Host" is just at "/control/epics/extensions/src/edm/edmMain". I have checked the "Makefile" at "/control/epics/extensions/src/edm/edmMain",but  still don't know how to do with the errors.
Thanks for your help!
                                                       huyong
Prev: RE: Record Type Doc Wayne Dahl
Next: compiling channel arhiver error Zhao Zhuo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Segmentation fault for CA client(EPICS 3.14.6) Jeff Hill
