1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: compiling channel arhiver error
To: [email protected]
Cc: [email protected]
Date: Thu, 9 Sep 2004 16:30:13 +0800 (CST)
---------- Forwarded message ----------
Hi,I'm building channel archiver(07/26/2004) on base3.14.6 for
linux-x86 -- linux-x86 architechture on redhat linux9.0.
I built all the required component in the directory "ThirdParty",include
expat-1.95.8
w3c-libwww-5.4.0
Frontier-RPC-0.07b4
xerces-c-src2_4_0
XML-Simple-2.09
xmlrpc-c-0.9.9
But it still showed the following error information:
Do you know the reason?
Installing library ../../../../lib/linux-x86/libTools.a
/usr/bin/ranlib ../../../../lib/linux-x86/libTools.a
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500  -DOSITHREAD_USE_DEFAULT_STACK      -D_X86_  -DUNIX
-D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -g  -Wall     -D ARCH_VERSION=2
-D ARCH_RELEASE=1 -D ARCH_PATCH=4 -D ARCH_VERSION_TXT=\"2.1.4\"
-I/home/epics/epics3.14.0alpha2/base-3.14.6/include
-I/home/epics/epics3.14.0alpha2/base-3.14.6/include/os/Linux
-I/home/epics/epics3.14.0alpha2/extensions/src/ChannelArchiver/ThirdParty/xerces-c-src2_4_0/include
-I. -I.. -I../../../../include/os/Linux -I../../../../include
  ../ToolsTest.cpp
/usr/bin/g++ -o ToolsTest  -L../../../../lib/linux-x86/
-L/home/epics/epics3.14.0alpha2/base-3.14.6/lib/linux-x86/
-L/usr/local/lib -lxerces-c
-Wl,-rpath,/home/epics/epics3.14.0alpha2/base-3.14.6/lib/linux-x86
ToolsTest.o
-lTools -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc
-lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread
-lreadline -lcurses -lm -lrt
/usr/bin/ld: cannot find -lxerces-c
collect2: ld returned 1 exit status
gmake[2]: *** [ToolsTest] Error 1
gmake[2]: Leaving directory
`/home/epics/epics3.14.0alpha2/extensions/src/ChannelArchiver/Tools/O.linux-x86'
gmake[1]: *** [install.linux-x86] Error 2
gmake[1]: Leaving directory
`/home/epics/epics3.14.0alpha2/extensions/src/ChannelArchiver/Tools'
gmake: *** [Tools.install] Error 2
Prev: Strange errors occur when stalling edm-1-10-0c on redhat 9.0 胡勇
Next: ? Gateway Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
