Jeff Hill wrote:
> What symptoms did you observe that led to finding this fix? I just read that
> Kate observed a hang (which I assume means that RTEMS shut down).
When I posted the original message in June, the IOC hung for a while
and rebooted itself. At that time, I was using the RTEMS-mvme2307
default exception handler. Also, there were other bugs in the
Oms58 motor driver, which complicated the issue.
Recently, I modified the improved exception handler that Till wrote for
the SVGM PPC board, and incorporated it into the mvme5500 board.
By doing so, the symptom is that RTEMS shuts down and leaves
information about the stack traces and register context. With those
information, Till was able to trace back manually using a disassembled
dump of the code.
The lesson I learn is that one can actually debug the RTEMS application.
The key point is to sharpen the skill of understanding the assembly codes.
P.S. : The source codes of the mvme5500 BSP will be available
upon request next week. I will post this again after I update the
the cexp and GeSys to the latest release that Till posted
on his "RTEMS Evaluation CD".
Cheers,
Kate
- RE: ca_repeater bug (probably observable only on RTEMS) Jeff Hill
RE: Understand the EPICS fdmgr functions Jeff Hill
Re: ca_repeater bug (probably observable only on RTEMS) Kate Feng
<2004>
2025
2026
<2004>
2025
2026
