1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_repeater bug (probably observable only on RTEMS)
To: Jeff Hill <[email protected]>
Cc: "'Till Straumann'" <[email protected]>, Eric Norum <[email protected]>, [email protected]
Date: Fri, 17 Sep 2004 16:04:57 -0400
Jeff Hill wrote:
> This code was written a long time ago. With R3.13 it executes as a thread
> only on vxWorks, and on vxWorks exit() causes only the thread to exit.
> Of course, now with R3.14 the code runs also on other OS where exit() may
> have a different behavior. In particular, on Linux, Solaris, HPUX, Windows,
> etc exit() will cause the process to exit, but that behavior should not be
> observed because osiSpawnDetachedProcess() is implemented on these systems,
> and therefore the CA repeater always runs in an independent detached
> process. It is not running as a thread in the IOC as is the case with
> vxWorks.
> That leaves RTEMS. The osiSpawnDetachedProcess() function is not (probably
> cant be) implemented on RTEMS and so you will end up with the CA repeater
> running as an RTEMS thread. However, perhaps on RTEMS exit() causes the
> RTEMS OS to shut down? That might be a more appropriate implementation of
> exit() compared to vxWorks.
However,  the IOC  did not exit and  cause RTEMS shut down if I  add
one clock tick of  delay after motor initialzation.  It works fine for  the
workaround.    Assuming the answers to the above questions are yes,
perhaps EPICS  had  enough intelligence to  undo the OS exit() if given
one clock tick of delay to  figure out ?   Is this why the workaround works ?
Kate
> What symptoms did you observe that led to finding this fix? I just read that
> Kate observed a hang (which I assume means that RTEMS shut down).
> Thanks for bringing this to our attention.
> Jeff
> > -----Original Message-----
> > From: Till Straumann [mailto:[email protected]]
> > Sent: Wednesday, September 15, 2004 5:34 PM
> > To: [email protected]
> > Subject: ca_repeater bug
> > Folks.
> > the caRepeater thread calls 'exit()' which is not really
> > what you want to do from the ca server (I guess)
> > -- T.
RE: ca_repeater bug (probably observable only on RTEMS) Jeff Hill
Prev: Re: ca_repeater bug (probably observable only on RTEMS) Kate Feng
Next: RE: ca_repeater bug (probably observable only on RTEMS) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
