I am writing support for an arbitrary waveform generator (Joerger Model
VDACM 8 channel, 16-bit, 100kHz, waveform generator with 32k memory per
channel).
Is there an EPICS record which is appropriate for such a device? The aao
record seems like a possibility, but a search of tech-talk archives from
1996 and 2000 revealed a number of problems with this record which don't
appear to have been incorporated into later releases (looking at
aaoRecord.c from R3.13.10).
The waveformRecord is close, but is designed for readback, not output like
I need for this device. The gensub record may be a way to deal with it, if
necessary.
Is anyone using a similar device, and if so, what record are you using?
Also, any suggestions on user interface for loading and modifying
waveforms?
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
- Re: EPICS waveform output record Carl Lionberger
Re: ca_repeater bug (probably observable only on RTEMS) Till Straumann
RE: EPICS waveform output record Rogind, Debbie
<2004>
2025
2026
building Interviews for gdct under solaris and gcc Dale L. Brewe
<2004>
2025
2026
