1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS waveform output record
To: "Steven Hartman" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Wed, 22 Sep 2004 15:24:09 -0700
Hi Steve,
You may want to contact Richard Dabney ([email protected]) who wrote support for the Joerger Model VWG 100MHz, 12 bit VME aribitrary waveform generator.
Debbie Rogind
Stanford Linear Accelerator Center, MS-46
2575 Sand Hill Road, Menlo Park, CA 94025 USA
Phone: 650.926.5183
> -----Original Message-----
> From: Steven Hartman [mailto:[email protected]]
> Sent: Wednesday, September 22, 2004 2:21 PM
> To: EPICS tech-talk
> Subject: EPICS waveform output record
> I am writing support for an arbitrary waveform generator
> (Joerger Model VDACM 8 channel, 16-bit, 100kHz, waveform
> generator with 32k memory per channel).
> Is there an EPICS record which is appropriate for such a
> device? The aao record seems like a possibility, but a search
> of tech-talk archives from
> 1996 and 2000 revealed a number of problems with this record
> which don't appear to have been incorporated into later
> releases (looking at aaoRecord.c from R3.13.10).
> The waveformRecord is close, but is designed for readback,
> not output like I need for this device. The gensub record may
> be a way to deal with it, if necessary.
> Is anyone using a similar device, and if so, what record are
> you using?
> Also, any suggestions on user interface for loading and
> modifying waveforms?
> Thanks,
> Steve Hartman
> [email protected] || 919-660-2650
> Duke Free Electron Laser Laboratory
Prev: EPICS waveform output record Steven Hartman
Next: Re: EPICS waveform output record Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS waveform output record Luedeke Andreas
Next: [no subject] J. Frederick Bartlett
