Hi again- now that I know it's the "-mstrict-align" that's causing the
byte operations, I still have 2 questions...
1) I see that this switch is provided by EPICS/base/config/CONFIG.Vx.mv2400:
ARCH_DEP_CFLAGS = -mcpu=604 --no-builtin -mstrict-align -mlongcall
What's the proper way to override this in a local work area config directory?
2) What switch (or lack of) does this compiler need to turn this feature off?
A quick naive test of re-running just the gmake-generated ccpcc command without
the mstrict switch makes the assembly phase barf, though I'm easily convinced
that this may be due to the lack of proper environment caused by running it
in isolation:
as: error: unknown option 'p'
usage: as [-V] [-Q{y,n}] [-f[O][if]#] [-q] [-s]
[-S] [-K {pic,PIC}] [-o objfile] [-L] [-T]
[-P [[-Ipath] [-Dname] [-Dname=def] [-Uname]]...]
[-m [-Ym,path]] [-n] [-ul] [-xF] [-xarch=v7] [-xarch=v8] [-xarch=v8a] [-xarch=v8plus] [-xarch=v8plusa] [-xar\
ch=v8plusb] [-xarch=v9] [-xarch=v9a] [-xarch=v9b] [-xcode={pic13,pic32}] file.s...
thanks,
Mike
- RE: PPC compiler splits up ints & shorts? Steven Hartman
- Re: PPC compiler splits up ints & shorts? Andrew Johnson
Re: TRAPWRITE does not log settings made with ca_put_callback Andrew Johnson
<2004>
2025
2026
RE: PPC compiler splits up ints & shorts? Lawrence T. Hoff
<2004>
2025
2026
