1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PPC compiler splits up ints & shorts?
To: "Laznovsky, Michael" <[email protected]>
Cc: [email protected]
Date: Thu, 30 Sep 2004 14:53:16 -0500
Laznovsky, Michael wrote:
Hi again- now that I know it's the "-mstrict-align" that's causing the
byte operations, I still have 2 questions...
1) I see that this switch is provided by EPICS/base/config/CONFIG.Vx.mv2400:
ARCH_DEP_CFLAGS = -mcpu=604 --no-builtin -mstrict-align -mlongcall
What's the proper way to override this in a local work area config directory?
You should be able to just include a new definition of ARCH_DEP_CFLAGS in your Makefile, inside an architecture test comparing $(T_A) against your specific target arch.
2) What switch (or lack of) does this compiler need to turn this feature off?
   A quick naive test of re-running just the gmake-generated ccpcc command without
   the mstrict switch makes the assembly phase barf, though I'm easily convinced
   that this may be due to the lack of proper environment caused by running it
   in isolation:
Correct, the R3.14 build system sets up some environment variables that tell the compiler where to find its components.
You should read this tech-talks message first though, which describes why we added that -mstrict-align flag in the first place:
http://www.aps.anl.gov/epics/tech-talk/2000/msg00529.php
You can discover whether your compiler includes the fix for that original problem by running
<tornado>/host/<arch>/bin/ccppc -v
If you find the number 28373 in the output from that command you *may* be ok to omit the -mstrict-align in that our original bug *probably* wont recur.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
RE: PPC compiler splits up ints & shorts? Laznovsky, Michael
Prev: RE: PPC compiler splits up ints & shorts? Steven Hartman
Next: Channel Archiver Java Client on Windows Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re [18] Rebekah Leary
