I am trying to compile cmlog R2.1 PROD-2 on linux debian system.
I exported the WRAPPER_ROOT and ran make linux, but somewhere along the
way this error(s) happened.
The daemon also failed to build, most probably because of this error.
Should I do anything else before running make?
Best regards,
Gasper Pajor
make[3]: Entering directory
`/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace'
mkdir -p .obj/Linux-i386
g++ -I. -I.. -DLinux -g -c ACE.cpp -o .obj/Linux-i386/ACE.o
ACE.cpp:333:1: warning: "RLIMIT_NOFILE" redefined
In file included from /usr/include/sys/resource.h:25,
from ../ace/OS.h:829,
from ../ace/ACE.h:19,
from ../ace/IPC_SAP.h:19,
from ACE.cpp:2:
/usr/include/bits/resource.h:64:1: warning: this is the location of the
previous definition
g++ -I. -I.. -DLinux -g -c Addr.cpp -o .obj/Linux-i386/Addr.o
g++ -I. -I.. -DLinux -g -c ARGV.cpp -o .obj/Linux-i386/ARGV.o
g++ -I. -I.. -DLinux -g -c Date_Time.cpp -o .obj/Linux-i386/Date_Time.o
g++ -I. -I.. -DLinux -g -c Event_Handler.cpp -o
.obj/Linux-i386/Event_Handler.o
g++ -I. -I.. -DLinux -g -c FIFO.cpp -o .obj/Linux-i386/FIFO.o
g++ -I. -I.. -DLinux -g -c FIFO_Recv.cpp -o .obj/Linux-i386/FIFO_Recv.o
g++ -I. -I.. -DLinux -g -c FIFO_Recv_Msg.cpp -o
.obj/Linux-i386/FIFO_Recv_Msg.o
g++ -I. -I.. -DLinux -g -c FIFO_Send.cpp -o .obj/Linux-i386/FIFO_Send.o
g++ -I. -I.. -DLinux -g -c FIFO_Send_Msg.cpp -o
.obj/Linux-i386/FIFO_Send_Msg.o
g++ -I. -I.. -DLinux -g -c FILE.cpp -o .obj/Linux-i386/FILE.o
g++ -I. -I.. -DLinux -g -c FILE_Addr.cpp -o .obj/Linux-i386/FILE_Addr.o
g++ -I. -I.. -DLinux -g -c FILE_Connector.cpp -o
.obj/Linux-i386/FILE_Connector.o
g++ -I. -I.. -DLinux -g -c FILE_IO.cpp -o .obj/Linux-i386/FILE_IO.o
g++ -I. -I.. -DLinux -g -c Get_Opt.cpp -o .obj/Linux-i386/Get_Opt.o
g++ -I. -I.. -DLinux -g -c Handle_Set.cpp -o .obj/Linux-i386/Handle_Set.o
Handle_Set.cpp: In member function `void ACE_Handle_Set::sync(int)':
Handle_Set.cpp:111: error: 'struct fd_set' has no member named '__fds_bits'
Handle_Set.cpp: In member function `void ACE_Handle_Set::set_max(int)':
Handle_Set.cpp:131: error: 'struct fd_set' has no member named '__fds_bits'
Handle_Set.cpp:136: error: 'struct fd_set' has no member named '__fds_bits'
ACE_Handle_Set_Iterator::operator++()
Handle_Set.cpp:172: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp:183: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp: In constructor `
ACE_Handle_Set_Iterator::ACE_Handle_Set_Iterator(const ACE_Handle_Set&)':
Handle_Set.cpp:201: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp:205: error: 'const struct fd_set' has no member named '
__fds_bits'
make[3]: *** [.obj/Linux-i386/Handle_Set.o] Error 1
make[3]: Leaving directory
make[2]: *** [linux-redhat6.0-x86] Error 2
make[2]: Leaving directory
make[1]: Leaving directory
`/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0'
Hi, Gasper:
We have not compiled cmlog on debian linux distribution. However, we
have compiled cmlog on various RedHat linux distributions. The error
messages you saw were related to a incorrect ace config.h file and
incorrect Linux configuration in the Makefile.config. In the
CMLOG/C++/SACE-4.0/Makefile.config, you may want to change linux: or
linux-th: to point to linux-redhat8-x86(th). Similarly you want to make
the same change to CMLOG/Makefile.config. Even though there are
differences between RedHat and Debian distributions, I hope the redhat
configuration will serve as a starting point for your debian box. If
you have any question, please let us know. Thanks.
Jie Chen
Thomas Jefferson National Accelerator Facility
12000, Jefferson Ave.
Newport News, VA 23606
(757)269-5046 (office) (757)269-6248 (fax)
[email protected]
cmlog compile problems Gasper Pajor
Not-a-number (nan) issues Kay-Uwe Kasemir
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
