Hi all,
The instructions for RTEMS-mvme5500 are simple :
MVME5500> gevEdit mot-script-boot
(Blank line terminates input.)
tftpGet -a4000000 -cxx.xx.xx.xx -sxx.xx.xx.xx -m255.255.254.0 -d/dev/enet0
-fepics/hostname/bin/rtems5500-cexp.bin
netShut
go -a4000000
Update Global Environment Area of NVRAM (Y/N) ? Y
MVME5500>
Note : (cxx.xx.xx.xx means the client IP address and
sxx.xx.xx.xx means the server IP address)
The mvme5500 BSP is being added to the new RTEMS4.7 source tree,
which might take a while. Meanwhile, I posted the entire
RTEMS-4.6.0 release with the MVME5500 BSP and patches applied at
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software
It can be downloaded via :
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/rtems-4.6.0_mv5500.tar.gz
Sorry if you think this is irrelevant.
Kate
"Singleton, SJ (Steve)" wrote:
> Hello Ralph
> Here are the instructions I wrote for people here at Diamond:
> 4.2 Loading the Boot ROM to Flash Memory
> This is necessary for new processor cards or to load a modified boot ROM.
> First power down and take out the processor, change jumper J8 (situated at
> the top back corner of the board) to boot from Flash 1 instead of Flash 0,
> insert the processor and power up again. The following represents the
> necessary input/output on the debug port; user input is shown in bold;
> comment is in italics:
> Copyright Motorola Inc. 1999-2003, All Rights Reserved
> MOTLoad RTOS Version 2.0, PAL Version 1.1 RM02
> Tue Jul 1 16:34:30 MST 2003
> MPU-Int Clock Speed =1000MHz
> MPU-Ext Clock Speed =133MHz
> MPU-Number/Type = 0/MPC7455
> MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
> MPU-Ext Cache(L3) = 2MB, Enabled, 200MHz, L3CR=0xDF826000
> Reset/Boot Vector =Flash1
> Local Memory Found =20000000 (&536870912)
> User Download Buffer =005C3000:007C2FFF
> MVME5500> netShow
> Interface EAddress Status Speed Duplex
> /dev/enet0 0001AF0B1BEC Down Unknown Unknown
> /dev/enet1 0001AF0B1BED Up 100MBS Full
> MVME5500> gevEdit mot-/dev/enet1-cipa or /dev/enet0 if that is the
> active Ethernet port.
> 130.246.98.xxx The IP address of the MVME5500
> Update Global Environment Area of NVRAM (Y/N)? Y
> MVME5500> gevEdit mot-/dev/enet1-sipa or /dev/enet0 if that is the
> 130.246.98.xxx The IP address of the machine from which the boot
> ROM is to be loaded.
> MVME5500> gevEdit mot-/dev/enet1-gipa or /dev/enet0 if that is the
> 130.246.96.254 The IP address of the gateway
> MVME5500> gevEdit mot-/dev/enet1-file or /dev/enet0 if that is the
> /tftpboot/mv5500.ROM The name of the boot file
> MVME5500> tftpGet -d/dev/enet1 -r1 -v
> Network File Load in Progress...
> []><<<<<<<<<<<<<<<<<<< etc <<<<<<<<<<<<<<<<<<
> Bytes Received = &605920, Bytes Loaded =&605290
> Bytes/Second = &605290, Elapsed Time =1 Second(s)
> MVME5500> flashProgram -o01f00100 -nfff00
> Source Starting/Ending Addresses = 005C3000/006C2EFF
> Destination Starting/Ending Addresses = F3F00100/F3FFFFFF
> Number of Effective Bytes = 000FFF00 (&1048320)
> Program Flash Memory (Y/N)? Y
> Flash Memory Programming Complete
> The above seems to have worked for us; hope it helps with you.
> Regards
> Steve
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Ralph Lange
> Sent: 01 November 2004 13:17
> To: EPICS Tech-Talk
> Subject: MVME 5500/6100: How to flash the VxWorks bootrom?
> Hi all,
> with those new PPC board series Motorola seems to have switched from the
> good old PPCbug to something called MOTLoad.
> Does anyone have a clue or - even better - instructions on how to
> download and flash the VxWorks bootrom on one of these boards?
> Thanks a lot,
> Ralph
- DST adjustment Peter Groszkowski
- RE: MVME 5500/6100: How to flash the VxWorks bootrom? Singleton, SJ (Steve)
<2004>
2025
2026
<2004>
2025
2026
