1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DST adjustment
To: "'Peter Groszkowski'" <[email protected]>, <[email protected]>
Date: Tue, 2 Nov 2004 08:32:11 -0700
Beginning with EPICS R3.14 a new "epicsTime" library in libCom obtains its
UTC offset and daylight savings configuration directly from the ANSI C
library, and therefore from whatever facilities might be provided in the
local OS for this purpose. The EPICS_TS_MIN_WEST configuration is used only
by tsSubr which is now considered to be a deprecated legacy interface unused
by base but retained to provide backwards compatibility for the EPICS
extensions.
> -----Original Message-----
> From: Peter Groszkowski [mailto:[email protected]]
> Sent: Monday, November 01, 2004 8:52 PM
> To: '[email protected]'
> Subject: DST adjustment
> Hello:
> Is there an elegant way of turning automatic daylight savings time
> adjustment off?
> I am using Release 3.13.4 and from looking at /base/src/libCom/tsSubr.c
> it would seem like the best way would be to just modify
> tsStampFromLocal() and tsStampToLocal() and recompile. Not seeing
> anything that could be set through the environment.
> Ideally I want to have only EPICS_TS_MIN_WEST dictate the offset from UT
> time, and that can be easily set in the environment.
> Thanks,
> Peter
DST adjustment Peter Groszkowski
Prev: DST adjustment Peter Groszkowski
Next: Channel Access Protocol Specification Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
