1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Options for local booting of vxWorks and applications
To: Epics Questions <[email protected]>
Date: Wed, 10 Nov 2004 13:25:33 -0800
Possibility 1
The normal boot mechanism is to burn the bootrom code
into flash. What I have done on occasion (with an mv162) is to burn
standalone vxWorks into flash and place my application on
a ram disk (configured from onboard battery backed RAM)
From power on to application running takes 11 seconds.
However I have never tried this method to load epics
due to BBRAM size limitions. I think you could do something
similar with an MVME-5500.
Possibility 2
We also have other vme iocs (x86 based) that boot from an on-board
Disc-on-chip. With big enough disc-on-chip your entire application would
fit. You will need a TrueFFS driver.
See http://www.m-sys.com/
Possibility 3
Also for an x86 system. We place the bootrom code or standalone
vxWorks in flash made visible to the BIOS as "option ROM"
This takes about 20-25 seconds to get an application running
most of which is the BIOS doing its think.
Graham.
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Andy Foster Sent: 10 November 2004 15:11 To: Epics Questions Subject: Options for local booting of vxWorks and applications
Hello All,
I was just investigating what options there are for booting
vxWorks applications locally, rather than across the network and
was wondering if any sites are already doing this?
It seemed that one option is to use a SCSI device with a DOS file
system attached.
Is anyone using Compact Flash or any other type of local memory?
I am really interested in solutions for the MVME-2700 and
the MVME-5500 (in the future).
What we are trying to achieve is faster local boots, reducing the
network traffic at system startup.
Many thanks for any comments and/or examples.
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
|Graham Waters, Control System Eng phone: (604)-222-1047 ext 6531 |
|TRIUMF --- University of B.C, Fax: (604)-222-7307 |
|Vancouver, BC, Canada e-mail: [email protected] |
|http://isacwserv.triumf.ca/edevel/homepage/graham01.html |
RE: Options for local booting of vxWorks and applications Baker, KA (Keith)
Prev: Re: linux ioc console Maren Purves
Next: NFS performance problems on vxWorks Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Options for local booting of vxWorks and applications Andrew Johnson
Next: Open Position at the Swiss Light Source Luedeke Andreas
